fuel pump advice
Old Feb 21, 2013 | 08:15 PM
paddler's Avatar
paddler
Soft fuel hoses while you're doing the pump?
If you're going to replace the stock mechanical fuel pump, you might as well replace the soft fuel hoses in there. You have to disconnect them from the fuel pump anyhow to get the pump out.
It's possible to do the pump without removing the turbo, but getting the banjo bolt started is a royal pain. Then you'll need a just-right length short 12-point box-end wrench to tighten, and you'll only get about 30 degrees of swing before having to pull of and reset. Turbo off should make the pump a good bit easier, but if the uppipe and pedestal bolts are seized, you may want to accept the pain of doing the pump with turbo on.
Old Feb 21, 2013 | 08:41 PM
fordpride's Avatar
fordpride
Doing the pump with the turbo on isn't that bad. Now if you have a Cali model then I feel for you.
Old Feb 21, 2013 | 08:49 PM
fordman67's Avatar
fordman67
If you really want a challenge.Just change the pump with the fuel bowl intact. I have done many like that.Never again. the bowl comes out just too easy. Replace the square cut seals at the other end of the banjo fixture while you are in there. they are a pain but not terrible with the turbo intact. its all available from clay. easy to get a good little list going just for some fuel leaks. Also make sure the fuel hoses do not have worm clamps.use the special hose and high pressure hose clamps.
UGA33
Mar 15, 2017 09:56 PM
baker1983
Jan 21, 2013 10:07 PM
73cntry
Oct 28, 2008 07:55 PM
Core250PSD
Oct 6, 2008 08:36 PM
jcab
Jan 8, 2006 10:42 PM
