fuel pump leak?
Old Jan 7, 2006 | 07:51 PM
jcab's Avatar
jcab
fuel pump leak?
I cleaned off the valley of the engine on my 97 diesel, let it dry out, and a day later saw slightly wet spot right under the fuel pump. I took the fuel filter housing away from the pump, and found the fuel lines going to the pump were old and cracked. MY QUESTION IS COULD THE FUEL PUMP BE LEAKING, AS WELL THE FUEL LINES?? I would hate to replace the fuel lines, install everything, and still have a leak. Is there a way to check the pump if it leaks, when it is off the truck?? Please give any directions you guys might think of. Thanks Jeff By the way the truck ran good before I found the leak.
Old Jan 7, 2006 | 09:37 PM
watermanh's Avatar
watermanh
When I had that problem I put a small piece paper towel under the pump to determine that it was in fact the pump leaking, which it was. The pump has a weep hole underneath that leaks when the seal goes out (like the weep hole on a water pump). When you change the pump you will have to remove the filter assembly so might as well change hoses at that time. Good luck, aloha.
Old Jan 7, 2006 | 09:40 PM
jcab's Avatar
jcab
too late to check pump
I've already removed the fuel filter housing partially, so I have no way to check, as you say with paper towel. Should I just replace pump, or is there a way to check pump after removing it? Thanks Jeff
Old Jan 7, 2006 | 11:04 PM
1997F-350's Avatar
1997F-350
get a mirror or something and see if its wet under the fuel pump...
try fixing the lines first...if your gonna remove the fuel pump you might as well replace it imho.
good luck
Old Jan 7, 2006 | 11:12 PM
jcab's Avatar
jcab
fuel pump special instructions
I have a kit from autozone used to remove fuel lines, and was wondering if you have experience using the tool to remove fuel pump metal lines from fuel pump? Thanks Jeff
good luck
Old Jan 8, 2006 | 08:33 AM
1997F-350's Avatar
1997F-350
pm sent..........
Old Jan 8, 2006 | 10:11 AM
jcab's Avatar
jcab
Pm??????
eXCUSE ME FOR NOT KNOWING WHAT PM MEANS? PLEASE DEFINE PM. THANKS JEFF
pm sent..........
Old Jan 8, 2006 | 12:49 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Private Message.
At the top right corner of the page, reight below where it says Welcome, jcab, it has "you last visited" and "privae messages". Nect to the private message link shoul dbe a number showing how many new messages you have. You can click on that private message link and it will take you to your message center in your user control panel.
Old Jan 8, 2006 | 08:26 PM
jcab's Avatar
jcab
pm not recieved??
I've checked my pm's, and have not recieved it. Last message was 12/1/05. Could you send it again. Thanks Jeff
pm sent..........
Old Jan 8, 2006 | 09:21 PM
1997F-350's Avatar
1997F-350
i forgot what i sent you...
Old Jan 8, 2006 | 10:42 PM
jcab's Avatar
jcab
fuel pump change instructions
Special instructions to change the fuel pump on a 97 diesel. Thanks Jeff
