Ignition switch power
Old Feb 21, 2013 | 07:38 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Have a no start on the 97, have no power from the red blue wire to the starter relay. Tested it with a test light and have no power coming out of the ignition swicth. I took a good used working switch and still have the same scenario. 128k 5 speed with the clutch interlock bypassed. All fuses seem good. Wondering about the circuits as i believe there are actually two wires that power the ignition side on this circuit. Thankx soooooooooo much, ROn
Old Feb 21, 2013 | 08:29 PM
glovemeister's Avatar
glovemeister
Did you hard wire your interlock before or after the issue?
Old Feb 21, 2013 | 10:08 PM
MONAVIERONJON
After with same symptoms. currently seeking research on the fuseable link. About to trace wires with and extra dash harness i have to see if they lead to the pcm. thankx
dustyroad
47
Jun 26, 2020 11:37 AM
Tim Enigma
Jul 14, 2015 01:14 PM
bar8190
Electrical Systems/Wiring
Aug 25, 2005 12:51 PM
X-1
Oct 31, 2004 08:39 PM
computerguy50
17
Apr 30, 2003 11:16 PM
