Fuel Leak Question
Old Mar 15, 2017 | 06:33 PM
UGA33's Avatar
UGA33
Fuel Leak Question
I've repaired a few fuel leaks on OBS 7.3 trucks before. It has been awhile since I've messed with one, but I'm trying to help a buddy track down a fuel leak. My question is this: Is it common for the actual lift pump to leak? I've got a dry area between the fuel bowl and lift pump. The crevice behind the fuel pump has a puddle and is dripping on the ground. Only place I can figure its leaking from is the actual pump. Doesn't appear to be coming from the banjo bolt on the back of the pump. Just wondering if I'm thinking correctly?
Old Mar 15, 2017 | 08:00 PM
green_95's Avatar
green_95
Yes the pumps have a weep hole just like water pumps do.
Old Mar 15, 2017 | 08:31 PM
UGA33's Avatar
UGA33
I guess the course of action is pump replacement correct?
Old Mar 15, 2017 | 09:31 PM
paddler's Avatar
paddler
And replace the little short hoses between bowl and pump while you're at it.
Old Mar 15, 2017 | 09:56 PM
UGA33's Avatar
UGA33
Thanks guys.
mjunk1
17
Feb 21, 2013 08:49 PM
baker1983
Jan 29, 2013 07:18 PM
baker1983
Jan 21, 2013 10:07 PM
cannonman
Jul 20, 2010 10:38 AM
