1983 6.9 starter
Old Feb 19, 2013 | 10:34 PM
1989_f250's Avatar
1989_f250
1983 6.9 starter
Is there a difference in starters between the 83-84 6.9's and the later models, the specs say the earlier ones are 10 tooth and the later are 13, will the later model 6.9/7.3 gear reduction one work?
Old Feb 20, 2013 | 12:05 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Im not sure what it takes, but i know most guy with direct starters usually swap to the gear reductions. might do some searching, but my guess is they interchange.
Old Feb 20, 2013 | 02:38 AM
IDI guy's Avatar
IDI guy
Yes, it will be better. The reason they went to a gear reduction is the compression of these engines makes it hard to crank over so they reduced the gears so it would make it easier on starters. The flywheel is the same.
Old Feb 20, 2013 | 02:19 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Yes because earlier 6.9's (83-early 84) had lower compression than all the other years. So they could use the old direct drive starters.
You will love the gear reduction if you put one on!
Old Feb 20, 2013 | 02:58 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you can get the OEM Mitsubishi gear reduction reman at auto zone with lifetime warranty priced decently to boot fyi.
duralast #16561.
Old Feb 21, 2013 | 03:39 AM
IDI guy's Avatar
IDI guy
Good to know. What CR are they running in those years?
Old Feb 21, 2013 | 06:02 AM
IDIDieselJohn
If I remember correctly, the older 6.9's is 19.5:1 ratio, compared to 21.5:1 on all others. Something like that.
tassmannn
Aug 4, 2017 07:10 AM
Marauder2004
29
May 29, 2016 05:59 AM
morimoto_87
Feb 4, 2010 01:45 PM
greythorn3
Dec 3, 2007 01:26 AM
fast77
Bronco II
Jan 18, 2002 06:57 PM
