I'd rather deal with a rough ride than bad gas mileage LOL. Usually when I take a speedbump it seems worse in the front.
I agree, those front coil spacers are most likely your problem then. My truck's suspension is much stiffer in the back. I can take speed bumps fairly well on the front wheels, but I have to ease the back wheels over them, or else get a jarring jolt to the my back. Unless the back is loaded up with a lot of weight, then speed bumps are much less of a problem. Albiet my truck has much stiffer back springs then yours. But with any truck, the back should be stiffer (when unloaded) as it's designed to hold a lot of extra weight.
Yeah I see what you're saying. I mean I still feel it in the back quite a bit, the back used to be a lot stiffer when I had 2" blocks back there but since I took them out it seems to be better.
puts more pressure on the spring causing it to compress more than stock and no load and put a load on it and you have the pogo stick or rubber band effect
