new shocks = rough ride
Oct 1, 2003 | 06:04 AM
I recently put 4 new shocks and tires on my ranger (dont get me wrong, they helped alot) but the ride seems to be getting rougher and rougher. Could it be the springs....suspension...?
any suggetions on brands too?
Oct 1, 2003 | 06:57 AM
what type, kind of shocks
Oct 1, 2003 | 04:47 PM
Monroe Sensa-Trac® Shocks all the way around
Oct 1, 2003 | 05:38 PM
Ive always liked the Sensa-tracs. maybe its the tires... or air pressure?
Oct 1, 2003 | 06:21 PM
tires are ViperTR RadialGT's...
the max psi is 44... so about how much should it be?
Oct 1, 2003 | 07:49 PM
Where are you getting 44? That's an odd number, are you looking at the pressure on the sidewall of the tire? You want the tire to wear evenly, so it's not necessarily the max psi. Do a search under "chalk test" in this forum, tire pressure is a very popular question and has been beat to death around here.
Oct 2, 2003 | 10:36 AM
sorry, i imagine so... but yah 44 is the max psi. i'll give the chalk test a try and hope that is the reason for the rough ride
Oct 5, 2003 | 07:03 PM
theres a sticker on the inside of one of the doors that tells you the factory recomened tire pressures
also check the ball joints and all the bushings!!!!!
i personaly don't like to put sensatracs on 4x4 pick ups
rather i would use the monroe "reflex" units if i had the extra bucks
Oct 5, 2003 | 07:12 PM
well, the tires arent factory size so i dont think that the recommended psi will apply.
i will check the ball joints and bushings though
mine isnt a 4x4 so the sensatracs should be doin fine...
351Cleveland C4
Apr 29, 2014 05:31 PM
SLAYER1
Jul 10, 2007 07:42 PM
Wrenchtraveller
Modular V10 (6.8l)
Jul 4, 2005 09:47 AM
Black4.2
3.8 & 4.2L V6
Jul 23, 2004 01:52 PM
Joe Griffin
Jun 14, 2000 04:21 PM
1995 ,
2010 ,
ball ,
f150 ,
ford ,
joints ,
ranger ,
ride ,
rough ,
shocks ,
stiff ,
test ,
truck ,
xltrough ,
xtype
