1978 - 1996 Big Bronco
Rough ride
Old May 29, 2002 | 09:03 PM
1stBronco's Avatar
1stBronco
Rough ride
I have a '96 XLT with the four shock setup in the front. There are Rancho RS5000 shocks all the way around. When driving, there is no give in the suspension. It feels like the shocks are locked. Is this the fault of the shocks or something else? BTW, here are Goodyear Wrangler AT/S 31x10.5x15 tires on it. I would like to soften the ride.
Old May 29, 2002 | 09:28 PM
cyberdr2's Avatar
cyberdr2
Rough ride
The ride is most likely due to the stiff shocks. I drove a bronco last month that had those same shocks on it and it was extremly rough and not comfortable to ride in at all. I have Gabriel shocks in my 93 Bronco. They seem to ride quit well on the road ( I don't do a lot of off roading). I get a much softer ride with them. You could try replacing one of the shocks on either side with a softer shock to see if it makes for a better ride. If not, then change out the others as well. You can probably sell the shocks you have on there with no problem. Good luck. Let us know what happens.
Old May 29, 2002 | 10:11 PM
restorit's Avatar
restorit
Rough ride
JayzDaddy
17
May 3, 2013 10:13 PM
SPRINGER340
Oct 9, 2012 09:44 PM
Texas Bob
Dec 9, 2009 08:32 AM
copeina
1997 - 2003 F150
Aug 13, 2002 06:42 PM
