Park brake help!
Old Feb 15, 2013 | 11:11 PM
Rivergreen74's Avatar
Rivergreen74
Park brake help!
Hey all, rebuilding a 74 F100. Replaced all brakes and the Emergency brake will not ratchet ( did not ratchet before brake job either). Looks like there is a cam that engages the brake pedal but I cannot see it. I sprayed everything down with lube- no luck. All wires are free, just when you depress the pedal it does not stay down. Replace assembly or can I fix it?
Old Feb 16, 2013 | 04:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo did not offer any parts for the park brake control except the release handle and the pedal pad. If the internal coil spring or any other part broke, the entire assembly had to be replaced.
D3TZ-2780-A .. Park Brake Control Assy / Obsolete
1973/75 F100/250 2WD/4WD / 1973/75 F350's on the 140" wheelbase // 1976/79 is not the same.
NOS PARTS LTD in Waxahachie TX has TWO = 972-937-2201.
No Ford Dealer, no other obsolete parts vendor has any.
Old Feb 16, 2013 | 09:40 AM
Rivergreen74
Thanks for the info ND. Good to know the parts are different after 75.
Old Feb 16, 2013 | 10:13 AM
POPAJON's Avatar
POPAJON
Number Dummy. I t will need a parking brake assembly the whole thing under the dash. Is there one available for a '77 f-150 XLT 2wd reg cab?
Old Feb 18, 2013 | 02:17 AM
NumberDummy
Originally Posted by POPAJON
I will need a parking brake assembly, the whole thing under the dash. Is there one available for a '77 F150?
D6TZ-2780-A .. Park Brake Control-Use without luxury decor group / 1976/79 F100/350 & 1978/79 Bronco / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D6TZ-2780-C .. Park Brake Control-Use with luxury decor group ~ Same as above, except pedal pad has a bright metal trim ring surrounding it / Obsolete
Old Feb 18, 2013 | 10:53 AM
brian1080's Avatar
brian1080
try taking the assembly out and soaking it in a pan of diesel or parts cleaner for a while. It may just be gummed up from years of spraying lube on it then dust collecting. I've fixed two just with a good cleanup.
Old Feb 18, 2013 | 12:57 PM
POPAJON's Avatar
POPAJON
OK I should have been a LOT clearer on what I was after. The mechanism is good. The cable from the lever under the dash to the rear cables has bee cut, so it's the main cable i am after. sorry for my giving the wrong info.
Old Feb 18, 2013 | 01:17 PM
NumberDummy
1977 F150: OK I should have been a LOT clearer on what I was after. The mechanism is good.
The cable from the park brake control to the rear cables has been cut, so it's the front cable I am after.
D6TZ-2853-B .. Front Parking Brake Cable / Obsolete
Applications: 1976/77 F100/150 2WD Regular Cab.
GREEN SALES CO. in Cincinnati OH has 6 = 513-731-3304 (greensalescompany.com).
WESLEY OBSOLETE PARTS in Liberty KY has 8 = 606-787-5293.
Green Sales ships "across the pond" via Fed-Ex. Dunno if Wesley does or not.
Old Feb 18, 2013 | 02:22 PM
POPAJON's Avatar
POPAJON
Thanks Bill. OH and BTW I live in Canada. Cranbrook Ontario to be exact R.R.3 Brussels is my mailing address as I live outside of Brussels Ontario. Popa John
Jules The Great
Nov 28, 2017 10:20 AM
lamenytro
1978 - 1996 Big Bronco
Aug 2, 2016 01:29 PM
Rusty_Old_F250
15
Oct 5, 2010 09:42 AM
DWV88
Jun 27, 2010 07:22 AM
dagray3
Jul 1, 2007 03:36 PM
