What would you do?
Old Mar 31, 2013 | 04:22 PM
BLADE35's Avatar
BLADE35
ITS GOING TO RUIN the engine without any coolant to stop the cavitation
They rust fast
Old Jun 27, 2013 | 09:40 PM
ford351c's Avatar
ford351c
I have finished with the flush and my "deltas" are now higher than they were before i started. They are about 30-35 with ECT at 194. I am going to replace the cooler. New question; while i have it torn down this far. Is there anything else worth changing? The truck is a 2005 model made in October 2004
Old Jun 27, 2013 | 11:12 PM
bismic's Avatar
bismic
Go ahead and change out the STC fitting and install the updated dummy plugs and standpipes (if this work has not already been done).
Are you planning on installing a BPD EGR cooler?
Old Jun 28, 2013 | 07:05 AM
mustang_309's Avatar
mustang_309
X2 on this.
Old Jul 7, 2013 | 07:09 AM
ford351c's Avatar
ford351c
you convinced me on the STC fitting, stand pipes and dummy tubes. Curious about the BDP EGR cooler. IS that brand better than the OEM? What symptoms would indicate is failing?
Old Jul 7, 2013 | 07:26 AM
npccpartsman's Avatar
npccpartsman
The BPD is quite a bit more robust than the OEM cooler. Typically when the coolant flow to the oil cooler gets restricted the EGR cooler itself gets a LOT hotter due to it's inability to be cooled and the solder joints melt internally. The cooler then starts leaking coolant into the cylinders and, depending on the severity of the leak, the engine hydro locks due to coolant in the cylinders.
Old Jul 7, 2013 | 07:28 AM
bismic's Avatar
bismic
The 05 and up OEM EGR coolers have a fairly high failure rate - especially after oil cooler plugging has been experienced (the coolant from the oil cooler flows into the EGR cooler, and if that flow was restricted for long, it adds stress to the EGR cooler).
lol - too slow .........
Old Jul 7, 2013 | 08:28 AM
69cj's Avatar
69cj
Since you have flushed it and are doing coolers, nows a good time to install a coolant filter.
Old Jul 17, 2013 | 11:59 AM
ford351c's Avatar
ford351c
I am planning on replacing the Oil cooler with an OEM one, BPD egr cooler, STC fitting, Stand pipes and dummy plugs. My question now is when i get all this apart to change the parts listed above. Are there any gaskets not included with these parts when taking something else off to gain access to, that i would need to replace as well?
As you can tell by the time frame of what is going on here i don't drive the truck much, but want to have everything ready to go when i start this.
Alex Villa
Apr 11, 2017 09:35 PM
VikingBabe
Apr 26, 2014 04:09 PM
06truck ED
Aug 26, 2008 07:07 PM
QUINCE
Apr 11, 2007 03:11 PM
wera racer
Aug 13, 2004 05:05 PM
