hey what does psd mean i see that alot of you guys are running fluidampner is that an aftermarket harmonic balancer my super duty is completly stock right now it has a build date of 10 2005 4wd crew cab with short bed i don't drive it that much i am saving it for retirement six years away i change the oil at 3000 miles and run diesel clean every time i put fuel in my baby should i switch to stanadyne i am going to check with the ford dealer about the head bolt issues what else should i be doing to try to moth ball my truck when i do use it i run it fairly hard i purchased this truck new from graham ford in columbus ohio
Actually his manual calls for fuel filter changes of 15,000 miles and if he is getting good fuel and adding cetane boosters and stabilizers he shouldn't have to change them at 10,000 mile intervals. In fact he will be changing oil at 6 month intervals instead of by mileage.
