Sponsored by: Real Truck
Running Cable to console
Old Feb 14, 2013 | 05:08 PM
Wingchop's Avatar
Wingchop
Hi, I have a 2012 F250 with a center console in the cab. I'm wanting to run a cable from my license plate camera (hooking up my travel trailer) up into the inside of the console. How do I get the cable from under the cab up into the console? Thanks
Old Feb 14, 2013 | 06:40 PM
jroberts257's Avatar
jroberts257
I would run the cable along your driver side frame rail up to your floor board under the pedals. There is a grommet you can run the wire through. From the top side you can pop off the door sill and get the wire from under the carpet through that grommet. Then you can work the wire over to the counsel under the carpet (which may be time consuming), or you could run it right up next to the seatbelt under the driver seat to the counsel. You would only see about 2 inches of wire and it would blend in next to your seatbelt.
Old Feb 14, 2013 | 06:45 PM
jroberts257
while your under the truck maybe you could check and see if there is a grommet closer to the counsel. I have used the one by the pedals for my CB antenna wire, but it seems like there should be one closer to the counsel too.
Old Feb 16, 2013 | 04:53 PM
Wingchop's Avatar
Wingchop
Bingo, job done, thanks
Daragh
May 23, 2018 12:29 PM
62vetteman
2015 - 2020 F150
Mar 31, 2017 11:53 AM
62vetteman
Mar 31, 2017 09:47 AM
Bsimmer3000
2009 - 2014 F150
Sep 9, 2011 08:36 AM
jlmotox
Jun 8, 2011 11:00 PM
