Weird Grinding / Vibration
Old Feb 14, 2013 | 10:13 AM
scottf4444's Avatar
scottf4444
I tried this over in the 6.0 forum but didn't get anything so hopefully someone here will have an idea...
After driving for about 15 minutes, once it is warmed up, at acceleration & low rpm's, there is a vibration, mild grinding noise. Once you get to mid-range and up on the rpm's, it goes away. When cruising down the highway at normal speeds and a consistant rpm...no noise. Idling at, and taking off from a stop light, I get the noise. The longer it is driven, the more noticeable the noise is. Possible torque converter??? Thanks!
Old Feb 14, 2013 | 10:48 AM
EpikExcursion's Avatar
EpikExcursion
Does it only make the grinding or vibration sound when you let off the gas while driving down the highway by chance?
Old Feb 14, 2013 | 10:51 AM
volthause's Avatar
volthause
This kind of noise?
Old Feb 14, 2013 | 11:36 AM
EXv10's Avatar
EXv10
Get a piece of hose, climb under and around, put it to your ear. Also take the inspection plate off the converter housing and take a peek.
Old Feb 15, 2013 | 12:28 PM
scottf4444's Avatar
scottf4444
Thanks for the replies.
Originally Posted by volthause
Pretty much dead on to what I hear. What is that?
Old Feb 15, 2013 | 01:12 PM
EXv10's Avatar
EXv10
I see your bottom cover is already off. Check around with that hose, hold it to the exhaust cat also, plus you can tape it to a funnel for a little broader noise range.
Old Feb 15, 2013 | 02:45 PM
volthause's Avatar
volthause
That is a flex plate cracking / failing. It's about $145 piece on the 7.3, so I would think it's about the same for 6.0. You can get more expensive / billet ones if you search around, they are more expensive though.
Transmission needs to be pulled to replace, but beyond that I don't know since I have not personally replaced one.
Good luck.
Old Feb 15, 2013 | 03:26 PM
scottf4444's Avatar
scottf4444
Seems I now know the culprit. Thanks for your help! Reps sent.
Old Feb 15, 2013 | 05:56 PM
EXv10's Avatar
EXv10
Wow, that could have done a LOT of damage. Pull the trans with the converter, unbolt what's left of the plate, and bolt a new one in. Hopefully the starter will sound the same and also; no balancing is needed.
sdviking
Mar 15, 2015 07:53 PM
superpelly
Nov 26, 2006 10:30 AM
beatupford
Jan 12, 2006 12:43 PM
