Sponsored by: Auxito
02' throttle "feathering" while cruising....
Old Feb 12, 2013 | 04:30 PM
swaman's Avatar
swaman
Hi Folks!
I just had an exhaust manifold replaced on my F-150. It has the small 8 cyl..
While the manifold was leaking, the truck of course ran like crap.....spitting, sputtering, barfing, etc.
Now that the manifold work has been done, the truck runs pretty well, except for some intermittent increase in throttle (not by me) when cruising at highway speeds. This is comperable to the "feathering" of the throttle that you would do when checking for engine noises.
Hard to explain without feeling dopey, but kind of a mild ruuum, ruuum, ruuum out of nowhere when I'm cruising along.
I drive a 5 hr. trip every weekend, and it will do this about every 10-20 minutes.
I hope this makes SOME sense.
Any suggestions of course, will be greatly appreciated!
THANX!
Old Feb 12, 2013 | 04:47 PM
Bluegrass 7's Avatar
Bluegrass 7
Which side was replaced?
Old Feb 12, 2013 | 07:19 PM
swaman's Avatar
swaman
It was the RIGHT side.
Thanks
Old Feb 12, 2013 | 07:47 PM
Spotty's Avatar
Spotty
Does the tach actually move?
Are you on cruise?
Are you on level pavement when it happens?
When you say "right side"....passenger side.. right?
Old Feb 12, 2013 | 08:34 PM
swaman's Avatar
swaman
This occurs regardless of the geography.....level or hilly.
Yup, it was the passenger side manifold.
Don't have cruise control or tach. You can definitely feel the truck surge with the engine rpm increase. even though each rev lasts about a second and they come is bursts of 4 to 8.
Old Feb 12, 2013 | 09:03 PM
72Highboy4x4's Avatar
72Highboy4x4
Mine does this too, usually while cruising, the only difference is it only does it maybe once or twice every 10-20 minutes...
Old Feb 12, 2013 | 09:08 PM
Spotty's Avatar
Spotty
If it only seems to do it in OD at say 45-55 mph, maybe a lean surge when the EGR opens????
Old Feb 12, 2013 | 09:12 PM
72Highboy4x4
yeah mine does it about the same. cruise set at 65 and all of a sudden seems like it wants to take off. then it stops. it will do it to me as well if i am sitting in the driveway and rev the truck to 2500 rpms, hold it steady, then itll rev about 300 rpms and then drop back to 2500.
Old Feb 12, 2013 | 09:14 PM
72Highboy4x4
i think a tuner will allow you to delete the EGR. I was thinking about doing that. along with adding to the transmission shift pressures and gas mileage.
Old Feb 14, 2013 | 07:02 AM
enriched&beyound's Avatar
enriched&beyound
possible vacuum leak...Elbow on the back side of the throttle body housing that goes to the PCV.
or the early signs of the weak COP....lazy O2 sensor?
2014coyote
5.0L Coyote
Aug 4, 2015 08:33 AM
Johny Maschinko
2004 - 2008 F150
Mar 18, 2012 02:32 PM
10088
Jul 14, 2006 02:36 PM
indian_outlaw87
Jan 31, 2005 09:58 AM
grazier1
Jun 29, 2000 04:04 PM
