Sponsored by: Auxito
Leaking tranny cooler lines!
Old Feb 13, 2013 | 07:14 PM
J ballan's Avatar
J ballan
Hello everyone, my 2003 screw's tranny cooler lines are leaking right where the rubber hose crimps onto the steel line. Has anyone tried to cut or remove the factory hose crimps and slide a piece of hose over the steel line and secure using hose clamps? If so what size of hose was used? How did you remove the factory crimps? You would think with all the technology out there now they could build some tranny lines that don't leak? Oh well, they did make it 120 000 km not to bad I guess. Thanks in advance for the help.
Old Feb 13, 2013 | 09:09 PM
rmccbride's Avatar
rmccbride
My 2002 was leaking last year where the bracket was attached.. I went to Home Depot and got I think 3/8" compression coupling and fixed it.. You should get a compression fitting that mates to a hose barb for going from metal tubing to hose. Use double hose type screw clamps to hold it on..
Old Feb 14, 2013 | 12:45 AM
Torky2's Avatar
Torky2
The cooler lines are not high pressure, so I would expect the crimp sleeve setup to be the same as on many engine coolant and heater lines which I have salvaged.
I use a dremel grinding disc, and grind through the crimp sleeve lengthwise, in two parallel cuts a ways apart. You can and will have to cut into the hose some with the disc, but don't cut so deep through the rubber that you hit the retaining ring on the tube itself. After the two cuts are made, stick the blade of a screwdriver into one of the cuts and twist to bend out the piece between the cuts. Two cuts are done so you can get the sleeve off. One cut won't do it, as you would have to try to bend and expand the whole sleeve to get it off.
Then use the same internal diameter sized hose as what is there now, and a clamp. Of course, use the proper hose type that is rated for cooler duty, hot oil.
Thanks goes to the guys at the ALLPAR forum many years ago for teaching me this, how to put new hoses on an incredibly expensive steel tubing set that went down the chassis to a rear heater on a van.
Old Feb 14, 2013 | 07:38 AM
J ballan's Avatar
J ballan
Awesome. Thanks very much for the replys. That's exactly what I was looking for. Looks like I have a nice little weekend project.
tractormanbill
May 26, 2014 07:22 PM
akamacgyver
23
Jul 25, 2012 08:32 PM
JT250
16
Mar 22, 2011 11:55 PM
Watcher
Mar 29, 2005 10:25 PM
JoeBlow
Apr 10, 2003 08:14 AM
