rear window defrost not working
Old Feb 12, 2013 | 12:51 AM
akboomer's Avatar
akboomer
rear window defrost is not working. button on dash light's up but times out without melting ice and snow. Tried the search not finding anything.
I did look for a blown fuse but cant seam to find one for rear defrost.
So here I am looking for help.
Old Feb 12, 2013 | 05:36 AM
ufvj217's Avatar
ufvj217
I'm not 100 percent sure but I think there's a wire plugs in somewhere on the rear glass. Check that maybe
Old Feb 12, 2013 | 08:46 AM
akboomer's Avatar
akboomer
Thanks I need to get into the shop to get a better look at it.
Still you would think there would be a fuse and I have yet to find one.
Old Feb 12, 2013 | 10:48 AM
jspence105's Avatar
jspence105
Defroster is fuse 24
I don't know if they are labeled, if not it's the third fuse down in the far right side.
Fuse 31 is the "on" indicator light
Old Feb 12, 2013 | 11:37 AM
EXv10's Avatar
EXv10
Fuses under the dash and under the hood. Look at the owners manual. It must be on a fused circuit.
Old Feb 12, 2013 | 01:32 PM
akboomer's Avatar
akboomer
l did look in the owners manual. did not see a rear window heat labeled fuse like say the mirror heat fuse.
I think there was a rear defrost but did not know if that slot was for rear heat/ac.
As far a under the hood I must of missed that in the O.M.
Any way please keep the options coming as I am to leave to go up north for a month or so for work.
Thanks
Old Feb 12, 2013 | 01:39 PM
jspence105's Avatar
jspence105
Is fuse 24 good?
Have you checked to see it you have power at the rear defroster?
Old Feb 12, 2013 | 02:42 PM
EXv10's Avatar
EXv10
Check any fuse that could possibly be it. Under hood and dash.
Old Feb 12, 2013 | 02:57 PM
jspence105's Avatar
jspence105
Old Feb 12, 2013 | 03:17 PM
akboomer's Avatar
akboomer
I pulled 24 it's good.
X is a 05 fuse box looks dif then your 01.
don't have test light or meter right now.
was wishing it was just a fuse I can't find still looking a pulling.
brutusroof
2009 - 2014 F150
Jan 4, 2018 08:34 AM
dlehmann
2004 - 2008 F150
Aug 17, 2009 07:53 PM
aztec12
Modular V8 (4.6L, 5.4L)
Sep 1, 2007 04:49 PM
ToiletDuck
1997 - 2003 F150
Mar 8, 2006 11:36 PM
killerklown
1978 - 1996 Big Bronco
Dec 1, 2003 02:54 PM
