Passenger side only Dome light help
Old Jan 2, 2018 | 09:17 AM
brutusroof's Avatar
brutusroof
I was installing LED lighting and must've blown a fuse. I lost power to the passenger side map light, garage door opener, and rear sliding window. The driver's side map light and moon roof all work fine.
I searched and couldn't find anything specific to only those items. I wouldn't mind searching thru all the fuses to see if one was blown but I live in Ohio and it's freakin freezing right now, and my truck doesn't fit in my garage. I also forgot to mention I must've bumped the rear window button before I blew the fuse cuz my rear window is stuck open about an inch in these frigid temps.
Any help would be greatly appreciated.
Last edited by brutusroof; Jan 4, 2018 at 08:36 AM. Reason: Originally incorrectly typed Dome light instead of Map light
Old Jan 3, 2018 | 07:24 PM
eriebasin's Avatar
eriebasin
Do you have your owners manual? According to my 2013 owners manual, the power windows and the power sliding back window are on a circuit breaker, not a fuse. Therefore, I'd say if your front windows work, then you have another issue. However, a raptor may be different. nonetheless, if you review your owners manual you should be able to sort out what fuse it is.
Good luck!
Old Jan 4, 2018 | 08:34 AM
brutusroof's Avatar
brutusroof
Sorry, I forgot to update my post yesterday. It was fuse #4 and it controlled the passenger side map light, visor mirrors, Homelink, and the rear window. I searched and got a bunch of different suggestions, including #21, 24, and 42 but I checked all those and they were fine. I replaced the #4 fuse and everything worked fine. Except my rear window was frozen open so I had to use my wife's hair dryer (I'm bald) to melt the ice to get it to close.
akboomer
Feb 12, 2013 03:17 PM
beaches
Jul 25, 2007 01:14 PM
ToiletDuck
1997 - 2003 F150
Mar 8, 2006 11:36 PM
Carp824
1997 - 2003 F150
Sep 28, 2004 08:48 AM
