help with fuse #
Old Sep 1, 2007 | 02:32 PM
aztec12's Avatar
aztec12
Question help with fuse #
Does anybody know what fuse number is for the control of the powerwindows.
my passanger window is not going up or down at all,so before taking it to the dealer i whant to make sure is not just a blown fuse tks.
by the way the truck is a 1998 f150 4.6 engine
Old Sep 1, 2007 | 04:49 PM
projectSHO89's Avatar
projectSHO89
If your original owner's manual is missing, you can down;load a copy from www.fleet.ford.com under MAINTENANCE.
Both windows are on the same fuse. If only one window is affected, then it's not a fuse problem. Common problems are the regulator motor, switches, wiring, and on thonse models where it's in play, the GEM module.
Steve
