Is it time to replace the injectors?
Old Feb 11, 2013 | 09:18 AM
ljfen's Avatar
ljfen
2002 engine has 243,000 on it. It ran well when it came in for the teardown. I've searched the forum but I am getting different opinions. Some say over 200,000 the poppet nozzles are gone. Others say the injectors should last to 400,000 with proper maintenance.
Once we get the 53 IH cab on permanently it is going to be difficult to get to the injectors. Should we rebuild them, buy new, buy rebuilt or slap the ones we have back in? Is there a way to test injectors out of the engine? Who has the best price on injectors rebuilt or new?
Old Feb 11, 2013 | 09:24 AM
Texas Chain Ring's Avatar
Texas Chain Ring
While I am no mechanic the obvious screams out to me to buy new and put them in before this cab install and be done with it to avoid any headache down the road.
Old Feb 11, 2013 | 09:56 AM
Texas Chain Ring
I can not say who the cheapest is but if you are wanting stock brand new OEM injectors by Alliant then DI Performance has them for not the listed price of $289.?? but for $250.00 each. I think Riff Raff is cheaper.
Stock OEM Powerstroke injectors
edit: While I did not see anything for brand new stock injectors here, Riff Raff sells rebuilt stock OEM's for $136.??.
Riffraff Diesel: Stock Rebuilt Injectors
Old Feb 11, 2013 | 10:26 AM
izzybird's Avatar
izzybird
First off, I want some pics of this '53 project! If you have the money to throw at injectors I would just go ahead and do it. You'll get a flood of opinions when it comes to injector talk. I would upgrade them to single shots, get the tuning to run them, drive that '53 with a smile. I have a friend with almost 450k on his stock injectors and not a drop of any kind of fuel additive. They are tired sure, but it's still pretty strong with no overly negative symptoms. Just an example. If you have no idea on how it lived its life in those 200k miles who knows. You'll have to do some tests to get a basic idea of what kind of shape their in. Can you start it?
Old Feb 11, 2013 | 10:28 AM
izzybird's Avatar
izzybird
Crud, I should really read before I type. I see you already have them out. Send them off to be tested.
Old Feb 11, 2013 | 11:23 AM
ljfen's Avatar
ljfen
Do you know who can test them? Cost?
Old Feb 11, 2013 | 02:53 PM
Robert6401's Avatar
Robert6401
This is where I would send them:
Rosewood Diesel Shop
Old Feb 12, 2013 | 12:57 AM
Tugly's Avatar
Tugly
Rosewood or Farmer... they're the only ones to have the reputation of making the injectors better than new.
Old Feb 12, 2013 | 01:59 AM
jkidd_39's Avatar
jkidd_39
http://www.riffraffdiesel.com/mm5/merchant.mvc?Screen=PROD&Store_Code=RRD&Product_Co de=FLOW73&Category_Code=F731-FS-CAS
This would be the most economical way to go.
If you are looking for a more performance orientated injector you could use those as cores. A set of stage 1s are only like $100 more than rebuilt stockers.
Apparently not everyone sees a mpg gain but I'm 2 for 2 on a nice jump in mpg.
Good luck and let's see this project plz
Old Feb 12, 2013 | 02:29 AM
BigAlsPSD's Avatar
BigAlsPSD
What is this based on?
Old Feb 12, 2013 | 04:51 AM
Tugly's Avatar
Tugly
Looking at this from a lawyer's perspective: "Reputation" means hearsay. I have no direct experience, but because the two names are mentioned... it's now worthy of at least a forum/internet search. I wouldn't go out and rattle off my credit card numbers on the phone just because one guy on a forum said "XYZ company has a great reputation"... and I hope the readers don't either.
willowbilly3
Oct 1, 2017 08:17 PM
BogginDave
17
Nov 13, 2015 09:26 AM
sju96ford
Jun 27, 2011 02:09 PM
paradiseandpalms
16
Nov 7, 2006 03:53 AM
sterling
Jan 20, 2005 09:11 PM
