Help decipher my oasis report
Old Feb 10, 2013 | 08:51 PM
ech0sh4y's Avatar
ech0sh4y
What are your thoughts?
VIN 1FTWW31P65ED00660
Vehicle Line T/F7 Market Derived Code F
Body Cab T/BC Ver. Series T/CD
Drive Type T/E
PLT CD A1 TRS CD T/BE ENG CD T/YB
Production Date 09-APR-05 Warranty Start Date 22-SEP-05
Selling Dealer 141389 Selling Country USA
AWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix Doc
Details 2376546 2 2 1.8 GRINWALD FORD, INC. 5753 05-NOV-05 * 7003 * 04545551
Customer Comments CHECK TRANS SHIFTING
Tech Comments OSION CONNECTOR,C1385, ON HARNESS 15525 CLEAN & RETEST OK
Details 3362478 2 3 0 VISTEON AFTERMARKET - U.S. 9877 15-DEC-05 5C3T 18C869 AA 27819000
Customer Comments
Tech Comments REQUESTING DEALER'S P/A CODE 06123
Details 2907620 2 3 .6 GRINWALD FORD, INC. 9877 19-DEC-05 * 18806 * 04661351
Customer Comments CD PLAYER INOP
Tech Comments CD PLAYER INOP RADIO REMOVE
Details 3591252 E83 5 .6 GRINWALD FORD, INC. 14724 14-FEB-06 * 18806 * 04810851
Details 3612283 05B35 5 .7 GRINWALD FORD, INC. 14724 14-FEB-06 * * * 04810841
Customer Comments 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments 05B35 RECALL MODULE RECALIBRATION
Details 3591251 05B32 5 .2 GRINWALD FORD, INC. 14724 14-FEB-06 * * * 04810840
Customer Comments 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments RECALL COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
Details 4064043 E83 5 0 VISTEON AFTERMARKET - U.S. 14224 14-FEB-06 5C3T 18C869 AH 27819300
Customer Comments
Details 3728179 E84 6 .5 GRINWALD FORD, INC. 15535 23-FEB-06 5C3Z 16720 SA 04836451
Customer Comments REPAIR FOR BOTH FRONT EMBLEMS PAINT PEELING
Tech Comments REPLACED BOTH FRONT EMBLEMS BLACK LETTERING WAS PEELING OFF
Details 5045288 E83 8 0 VISTEON AFTERMARKET - U.S. 20339 11-MAY-06 5C3T 18C869 AH 13137901
Customer Comments
Details 4610858 E83 8 .6 GRINWALD FORD, INC. 20359 11-MAY-06 * 18806 * 05056351
Customer Comments REPAIR FOR C.D.PLAYER INOPERATIVE, SEE HISTORY
Tech Comments C.D. PLAYER RADIO REMOVE
Details 6854095 P05 16 1.2 GRINWALD FORD, INC. 47596 20-DEC-06 5C3Z 14405 EA 05652151
Customer Comments REAR TRAILER HOOK UP CAP LOOSE
Tech Comments REAR TRAILER WIRING INOP WIRING ASSEMBLY REPAIR
Details 8111538 E72 22 15.6 MARITIME FORD-LINCOLN, INC. 60576 18-JUN-07 5C4Z 9A543 B 15503602
Customer Comments CUSTOMER STATES DOES NOT START TURNS OVER DOES NOT FIRE
Tech Comments CHECK OUT PERFORM TSB 06 17 06 DUE TO BRANCH TUBE WAS CRACKED AND FOLLOWED TSB TEST AFTER REPAIR STILL DOES NOT START CHECK BOTH HEADS HIGH PRESSURE PUMP ONLY PUTTING OUT 800 PSI DEAD HEAD REPLACE PUMP RETEST OK
Details 8111539 E72 22 16.4 MARITIME FORD-LINCOLN, INC. 60576 18-JUN-07 4C3Z 9B246 A 15503601
Customer Comments CUSTOMER STATES DOES NOT START TURNS OVER DOSENT FIRE
Tech Comments CHECK OUT NO CODES ICP LOW FOUND FITTING LEAKING CODE 2291 LOW ICP CHECK OUT FOUND BRANCH TUBE CRACKED CALLED TECH LINE PERFORM TSB 06 17 06 TEST AFTER REPAIR PERFORMED STILL WILL NOT START RETEST HAVE TO REPLACE PRESSURE PUMP REPLACED HIGH PRESSURE OIL PUMP
Details 8514656 E72 24 7.3 NORTHTOWN FORD, INC. 68606 27-AUG-07 6C3Z 9G282 AA 15627101
Customer Comments WILL NOT START, TOWED IN.
Tech Comments RAN IDS DIAG.P2293.ICP PRESS OK.CHECKED FUEL PSI LOW.FOUND FUEL PUMP NOT WORKING.POWER & GROUNDS TEST OK.BALLOON TESTED RIGHT BANK.FOUND COMPRESSION GASES LEAKING PAST INJECTOR #3 & CAUSE NO START.R&R #3 FUEL INJECTOR,FUEL PUMP,AND FUEL PRESSURE REGULATOR.ALSO R&R FUEL FILTER DUE TO LEAKING FROM TESTING.CLEARED DTC CODES.RETESTED OK.TOWED IN BY QUALITY AUTO BODY.
Details 9357821 S07 29 5 GRINWALD FORD, INC. 81570 30-JAN-08 5C3Z 6K682 CARM 06685051
Customer Comments CAC TUBES CAME OFF LOSES PWR.
Tech Comments TURBO STICKING INTERNALLY ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
The truck now has 97k miles. 2005 crew short xlt 4x4 auto asking $14k
Old Feb 10, 2013 | 09:34 PM
ho_shi's Avatar
ho_shi
what is a oasis report?
Old Feb 10, 2013 | 09:39 PM
Fal-308-Win's Avatar
Fal-308-Win
Is this your truck?? It's been in the shop 10 times!! My 06 has never been in the shop. I ran the warranty out with no issues,
Old Feb 10, 2013 | 09:40 PM
ech0sh4y's Avatar
ech0sh4y
No this is not my truck. I was looking to buy it however.
Old Feb 10, 2013 | 09:54 PM
04badford's Avatar
04badford
I hope your getting this thru a dealer with some kind of warrete and not a privite party with no warrente, one good thing is the hpop has been replaced
Old Feb 10, 2013 | 10:17 PM
CPB1's Avatar
CPB1
Looks like they messed around a lot with the HPO system. I did not see the replacement of oil cooler, or FICM. Almost all these engines need this at some point. It would pay you to take your ScanGauge2 on a test drive and check FICM volts and oil temps vs colant temps. Also see if the ICP is correct. Check ICP and IPR duty cycle.
Looks like the engine problems started around 60k.
What concerns do you have with it?
Old Feb 10, 2013 | 10:36 PM
ech0sh4y's Avatar
ech0sh4y
Well I've been reading about main issues. Not so much the hpop system. Also the fuel injectors. It is a private sale. I planned on bullet proofing but not right away. I just figured $14k in my area was a good deal. But maybe I should play it safe and keep looking.
Old Feb 10, 2013 | 11:25 PM
Fal-308-Win
No mention of STC Fitting or stand pipe and D plug work. My STC went out at 140K. So you would have that to look foward to . I did the work myself for $50. bucks, $1,500 at a shop like mentioned above take your SG2 with you. I've read on here to add $5K to the price for upgrades and then decide if its worth it? 8 or 9K sounds better
Old Feb 10, 2013 | 11:52 PM
04badford's Avatar
04badford
Hey fal,is it getting any warmer on that side of the hill, the amond buds are ready to pop so thats telling me spring is around the corner .
Old Feb 11, 2013 | 06:05 AM
mustang_309's Avatar
mustang_309
Im not sure when the updated STC fitting came out, but the new HPOP's come with the revised STC fitting so it may already have the new one.
Old Feb 11, 2013 | 01:38 PM
Idahoser's Avatar
Idahoser
I thought the branch tube was the STC fitting?
That's a lot of repeat problems, and not the one we know Ford got wrong a lot. I'd be suspicious of this truck unless I got it real cheap.
Old Feb 11, 2013 | 02:01 PM
Maxium4x4's Avatar
Maxium4x4
Not to bad but they never cleaned the EGR valve... Most of the related stuff was CD player and updates. Should have all the bugs worked out now.
Old Feb 11, 2013 | 02:43 PM
Fal-308-Win
I refuse to take part in this thread Hijack!! ( had the Fire Place going all Sun. Morn.)
Old Feb 11, 2013 | 11:40 PM
04badford's Avatar
04badford
Thanks Tim, its a little chilly, buds are on there way. got 20000 bees doing there work now.Maxium 4x4 great point on the EGRand health of the cooler?
ROBBINthaHOOD
Oct 5, 2011 06:25 PM
titanminator
31
Jun 6, 2009 05:45 PM
dtpatt21
May 24, 2009 08:41 PM
Firemudder
Apr 20, 2009 03:56 PM
remmers
Oct 21, 2008 04:56 PM
