My oasis report.
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 2 2E05 100106 6C3Z 9B249 A G29 42 8734
AWS Claim Key: 3063849 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2006 Doc #:00664153
Cust Comments: CHECK FOR WATER IN FUEL LIGHT ON
Tech Comments: HEADER FUEL FILTER REPLACE
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 2 6N04 010802 5C3Z 16720 VA B66 42 8734
AWS Claim Key: 3063848 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:04-JAN-2006 Doc #:00664151
Cust Comments: CHECK FOR PEELING FENDER EMBLEMS SOP IN
Tech Comments: REPLACED ALL 3 EMBLEMS
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 3 * * * * * * * 10386
AWS Claim Key: 3179969 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:00699041
Cust Comments: 05B35 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALIBRATE ENGINE CONTROL MODULES PER RECALL
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 5 * * * * * * * 20448
AWS Claim Key: 4212454 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:00910840
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: REPLACE LABEL ON DEGAS BOTTLE COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL AD
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 7 1H02 120307 6C3Z 2A451 A C05 42 28001
AWS Claim Key: 4782841 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-2006 Doc #:01097451
Cust Comments: CHECK FOR AC BLOWS FROM DEFROST ONLY
Tech Comments: BRAKE VACUUM PUMP ASSEMBLY REPLACE
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 8 6C06 011201 * 2627540 * B54 33 31703
AWS Claim Key: 5251194 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04529 - * Name: AL MEYER FORD, INC. Ph: 936-6326611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-JUL-2006 Doc #:01218251
Cust Comments: CK P S REAR ARMREST LOOSE AND POPPING UP
Tech Comments: REPAIR ARM REST TO FIT CORRECTLY
1FTSW21P85EC80159 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 16-MAR-2005 10-NOV-2005 152689 USA 30 1A02 030102 4C3Z 6051 EA E23 42 83824
AWS Claim Key: 9710809 Trx Code: E72 Labor Hrs: 23.9
Dlr Cd-Sub Cd: 05653 - * Name: SAMES CROW FORD LINCOLN Ph: 361-8517600 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2008 Doc #:586910A
Cust Comments: CUST STATES TRUCK OVER HEATED AND IS BLOWING WHITE SMOKE
Tech Comments: 83842 VEIFYED CUSTOMERS COCNERN, PREFOMRED DIESEL DIAG SHEET, DTCS PRESENT P0528 PREFOMRED TSB 08 3 7 PRESSURE TESTED COOLING SYSTEM NO LEAKS PRESENT, PREFORMED PINPOINT TEST AH3 FAILED TEST NO FAN OPERATION WHEN COMANDED PIDS, REMOVED A INSTALLD A NEW FAN CLUTCH,TEST DROVE VECHILCE STILL GETS HOT AND WHITE SMOKE PRESENT, PREFORMED EGR LEAK TEST VACUUMED COOLING SYSTEM WILL NOT
