ICP Problem
Old Feb 11, 2013 | 10:33 PM
tractordaryl's Avatar
tractordaryl
ICP Problem
04 250 6.0 just installed new icp sensor. 3 weeks later blowin oil everywhere is there a cause for blowing sensor? Or just bad sensor?part was factory
Old Feb 11, 2013 | 10:38 PM
powerstroke72's Avatar
powerstroke72
Thread moved to the 6.0L Powerstroke Diesel forum.
Old Feb 11, 2013 | 10:55 PM
dannyboy950's Avatar
dannyboy950
The 03 early 04 the sensor was bad for leaking thru the sensor, so bad for it Ford recomended to change the harness connector and pig tail automatically when changeing sensors.
The later 04 with the icp in pass. valve cover has a rubber gasket between the valve cover and oil rail, this sometimes gets damaged when replaceing sensor and leaks.
Old Feb 11, 2013 | 10:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
ICP on valve cover or on the HPOP with your 04 engine?
Josh
Old Feb 11, 2013 | 11:21 PM
tractordaryl
at back of motor ,replaced pig tail when I replaced sensor,any cause to blowin sensors back to back?
Old Feb 11, 2013 | 11:43 PM
dannyboy950
Unfortuneately some venders still have the old sensors on the shelf and will sell them.
You may have had the bad luck to get an old style sensor as a replacement. I know this cause my supplier from time to time slips an old style in on me.
dgulledge
Jan 29, 2015 08:10 PM
catalinaflyer
Aug 14, 2014 12:00 PM
tractordaryl
Jan 10, 2013 08:34 PM
jmullikin7
Dec 14, 2012 11:18 PM
gregh530
Mar 30, 2012 11:56 PM
