Starter motor SNAFU
Old Feb 8, 2013 | 05:53 PM
Walrus.'s Avatar
Walrus.
Starter motor SNAFU
G'day to all of the knowledgeable and well informed FTE's out there. I'm a first time poster, comparatively long time reader.
Just seeking clarification on fitting a new starter motor onto my 351 Clevo'.
The old starter motor has three connections- two smaller 'shoes' that fit over spigots (red and green ovals) either side of the main battery connection.
Uploaded with ImageShack.us
However, the new starter motor, lacks the spigot on the right side of the battery connection (the green oval)
Is this correct? Is the right side connection redundant with the new starter motor?
Thanks for your time,
Walrus.
Old Feb 9, 2013 | 07:12 AM
Franklin2's Avatar
Franklin2
What color is the wire that went to the green side? Does it happen to go to the coil + terminal? If so, that's your resistor bypass wire. I have never seen a Ford that has this type starter in the earlier years, only GM. Ford's usually have this bypass wire on the fender mounted solenoid.
jehawk55
Jan 31, 2012 08:51 AM
burninrubber2416
Oct 13, 2008 05:48 PM
78'Ranger
Aug 26, 2007 08:14 PM
coplin
Feb 26, 2007 01:24 PM
peterbond
Feb 20, 2002 08:00 PM
