Rev X
Old Feb 7, 2013 | 08:05 PM
brandon.edwards's Avatar
brandon.edwards
Rev X
I am thinking of trying this because i have heard and seen very good things. Anyone out there used this before? Ford dealer diagnosed i have 5 injectors bad, so i think im gonna try this before i go spend all my money. Let me know Powerstrokers.
Old Feb 7, 2013 | 08:29 PM
pile_53574's Avatar
pile_53574
WOW If U have 5 bad injectors, U need more than rev-x! Kinda sounds like u have FICM/Voltage problems. Do some more searchin on here, lots of info, Good luck!!
Old Feb 8, 2013 | 05:51 AM
brandon.edwards
my ficm voltage all checks out good. The only problems i have is my EGR cooler needs replaced, so i am deleting it. And injectors are bad.
Old Feb 8, 2013 | 10:39 AM
jebner's Avatar
jebner
My buddy used that Rev X stuff when he was having injector problems. He added to his oil change. It seemed like at first it was going to do something and then his injectors went right back to having problems. Bottom line is that you need to save your money from buying this stuff and replace your injectors. Besides it sounds like you may have more problems then just an injector problem...
Old Feb 8, 2013 | 11:12 AM
ChrisAU's Avatar
ChrisAU
I was having bad stiction on injector #8 and Rev-X almost immediately cleared it up, this was just a couple days ago. I used to have to wait 2-3 minutes at cold crank for the bad miss to go away and it would still miss up until temps got around 120. Completely gone now.
Old Feb 8, 2013 | 06:47 PM
cheezit's Avatar
cheezit
so your tring to figure out misfire issues with water entering cyclinders? fix one thing at a time you maybe ahead of the game.
also if i needed 5 injectors at one time i may think about replace all 8.
DerekF350disel
6.7L Power Stroke Diesel
50
Feb 25, 2016 09:25 AM
Roasted7
Sep 27, 2012 11:18 AM
branden.w
Nov 29, 2009 05:58 PM
"Luke" SdeS
Feb 29, 2004 02:43 PM
dpoelstra
May 16, 2003 02:38 AM
