Semi wheel - dually conversion
Old Apr 3, 2013 | 09:36 PM
  #31
Burnie3's Avatar
Burnie3
I Tried
Don't know if the link worked or not ... but i did add it as my avatar and in my garage. Kinda new to this ... I'll work on more pics later.
Old Apr 3, 2013 | 09:49 PM
  #32
dmanlyr's Avatar
dmanlyr
Originally Posted by Snowseeker
Anyone watch that shipping wars show? The one episode where the 10 lug conversion shears all the studs off the dodge and goes rolling away.
Yeah I am not a fan of wheel adapters, I've mentioned it a few times on here and talked about what can happen. The shipping wars show was a PERFECT example!
Yup I saw it. That was the first thing I thought - by putting those big rims and tires on with adapters all the person did was turn a real truck into a toy.
Which is fine if someone wants a big toy, but not when someone still wants to use the truck as a truck... like that guy did... he was lucky he did not hurt or kill someone with his mistake. I ride and shudder to think if that set of dualies would have hit a motorcyclist.
David
Old Apr 3, 2013 | 10:04 PM
  #33
dmanlyr's Avatar
dmanlyr
Originally Posted by Nsaan
Ya, I saw that one. I guess that is what happens when you don't check to make sure things are tight... Hey this sounds like the torque wrench conversation we had not too long ago.... Those 2 on the shipping show, robbie don't seem to work on their own stuff...
This is directly from their facebook page.
"JUST SO WE ARE CLEAR...There are no problems with the adapters on the 22.5 conversion, we have towed half a million miles with absolutely no problems! The lug nuts on the dodge were swapped at a local shop and that is what caused the studs to snap! You must use the correct lug nuts! These adapters have proven themselves up to 50k lbs!! THANKS!"
I don't know about you but I always either watch them when the torque my wheels on, or I check that they are tight when I get home.
Regardless of proper torque or not, the adapters and wider stance change the center line of the tires out farther, therby negating the factory design in that the centerline of the dualies is centered between the rear wheel bearings, which results in proper wheel bearing loading. Since the bearings are no longer properly loaded, this will result in a reduced capacity, no matter the design of the adapter. Or the lug nuts used. It is obvious by there Facebook posting that the guy has failed basic engineering school.
Hopefully some state DMV/DOT will red tag his rig until he is schooled.... before someone gets hurt or killed.
Moving the tires out also increases the leverage on the wheel studs, which only increases the leverage. This further reduces the load carrying capacity of the axle as compared to stock.
Additionally, the larger rolling diameter of the tires reduces the brake effectiveness, which again, reduces the capacity to haul a load and properly stop it.
Nope, on a load carrying truck, there is absolutely no reason to compromise the trucks load capacity. Upgrades should instead do just the opposite. After all, if what you change is not at least as good as what the truck came with, is it really a upgrade or in truth a downgrade...
Funny thing is this, you don't see these types of modifications on truckers class 5-6-7-8 rigs, nope, they don't put wrong offset wheels, adapters or huge tires on there trucks, they evidently are smarter than a lot would give them credit for. Ya, you see Alcoa wheels on these, but they are proper offset without adapters.... enough said!
While it is a bummer that government has to step in to take care of peoples ignorance (or is some cases plain stupidity), I for one do appreciate my states crackdown on these pirate rigs.
Again, if used a show truck, then these types of modifications are more usable, but not for a load carrying truck.
David
My two cents, David
Old Apr 4, 2013 | 02:02 PM
  #34
Apocalypse's Avatar
Apocalypse
I was never able to find a video for that storage wars, anyone have a link?
Old Apr 4, 2013 | 03:16 PM
  #35
Snowseeker's Avatar
Snowseeker
Here is a pic from the episode.
Old Apr 8, 2013 | 03:00 PM
  #36
jeeplj8's Avatar
jeeplj8
Originally Posted by mikeswae
Sorry guys- new here- Hope these pictures show up.
Example of quality (and functional) duel wheels on an ex.
Wow - that is awesome. is that your truck?
Old Apr 8, 2013 | 03:12 PM
  #37
dmanlyr's Avatar
dmanlyr
Nice looking conversion! Very nice indeed!
David
Old Apr 8, 2013 | 05:21 PM
  #38
mikeswae's Avatar
mikeswae
No belongs to my brother.
Full F-450 suspension and axels.
Fenders were custom made by a limo company in CA.
There is a hidden handle on the bottom to open the door.
Real COOL!!
Yougotthehit
Apr 3, 2013 07:38 AM
WheredaFoxhat
Nov 7, 2005 02:26 AM
dornauer
24
Oct 5, 2004 03:02 PM
Tony 1
Oct 10, 2002 09:05 PM
