DRW Conversion
Old Jul 24, 2004 | 10:37 AM
dornauer's Avatar
dornauer
DRW Conversion
Anybody ever convert a drw to a srw? I know they make kits for srw to drw. What would be involved converting to srw? New Rims? Could the fender extensions be removed from a 01 drw? When I purchased the truck I had planned on getting a fifth wheel trailer. Well things have changed and that is not in the future. Seems silly to drive around a drw. Any thoughts? Thanks
Old Jul 24, 2004 | 12:54 PM
RedTaurus94's Avatar
RedTaurus94
Hmmmm....different rims....ones that fit a SRW, take off the extenders in the front, remove the outboard fenders....that should get you there. Remember, you'll have to patch the fender bolt holes in the bed sides. I think there are a few folks that hang out here that have done the same thing and can give you more details.........
Old Aug 5, 2004 | 11:41 PM
shoobear's Avatar
shoobear
im looing at doing the same conversion. I hear that the bed is hacked out under those rear fenders. Let me know what is involved.
Cheers
shawn
Old Aug 6, 2004 | 11:51 AM
mtncrawler's Avatar
mtncrawler
The only dualie I'm familiar with is one of our work trucks which is 4X4 but when looking at it it sure seems like the front wheel hubs have a wider offset to work with the wheel rims. Switch them too?
Old Aug 6, 2004 | 11:32 PM
psdpower's Avatar
psdpower
The bedsides under the duallie fenders are all hacked up. The easier and probably cheaper way to do it would be to buy a whole srw bed from a recycler or a place that installs utility bodies. If your truck is one of the more common colors you might even get lucky and find a match.
Old Aug 7, 2004 | 12:56 AM
Fire Rooster's Avatar
Fire Rooster
There is a white short bed (just The box and tailgate with lights) for sale just down the road from the fire stn here in phx. Let me know if you want the price and info I will stop for you.
Fire Rooster
Old Aug 21, 2004 | 12:05 AM
shoobear's Avatar
shoobear
Talking drw to srw
ok, so i finally got my 2001F350 dually( only cause it was a good deal) and am ready to do the conversion to srw. So........... anybody have any knowledge or info it would be GREAT! Or even some part numbers! I think the front hubs have a extender on it that can be unbolted or replaced with a srw hub, and as far as the rear axle,......?????
Cheers
shawn
Old Aug 21, 2004 | 12:57 AM
f250rangerexplorer's Avatar
f250rangerexplorer
why do you want to change to SRW. i have a drw and srw and like the drw way better(ie stability, traction, etc except tire money)
Old Aug 21, 2004 | 08:07 AM
RedTaurus94
I am pretty sure that there is no difference in the front hubs other than the extenders. Once you take them off, I think you can bolt up a wheel/tire from a SRW. The rears may be a different story, but I cannot remember. Hopefully the SRW rims will bolt right up once you remove the duals.........
Old Aug 21, 2004 | 08:51 AM
blackf3504dr's Avatar
blackf3504dr
I believe there are extenders on the rear also , to compensate for the inside wheel being reverse mounted . The dually bed is not the same as on SRW , on some duallies ( not sure about Ford ) the frame and rear axle is narrower also . You can remove the adaptors on the front and bolt up the single style wheel .
Old Aug 21, 2004 | 08:54 AM
f350xlt460's Avatar
f350xlt460
ive heard that at least on some older trucks that the rear axle on a dually is wider. That could be an issue if it is true on the newer trucks too.
Old Aug 21, 2004 | 04:35 PM
bigpowerstroke's Avatar
bigpowerstroke
There is a website called arrowcraft.com they make kits for trucks
Old Aug 21, 2004 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The dually rear end is 4" wider than a SRW rear end.
The beds are the same on both, the dually just has been chewed on with a saw before the flares went on.(Actually different outside skin panels)
The frames are the same on the trucks that had a bed installed from the factory, if it came as a cab and chassis the frame is narrower.
Bolt patterns of the wheels are the same for dual and single wheels.
Old Aug 21, 2004 | 09:43 PM
shoobear's Avatar
shoobear
Hey i was looking under my dually fender and it looks like a stock bo with some sawzal chop job) Any idea if some stock rims would bolt up to the rear axle? Since its 4" wider-2" each side i would think that they might bolt up..... as long as they clear the disc caliper. Im gonna give it a try, didnt really wanna swap axles eh!
cheers
shawn
Old Aug 21, 2004 | 10:23 PM
silverado3500's Avatar
silverado3500
Talking
Man I wish you lived closer to me, I have a 2000 F350 SRW, and would like to switch to DRW. Heck I'd trade beds, wheels, rear axle, everythign, My truck is 4x4 with the 8ft bed. And I'm just about to put a new paintjob on it.
