Cdr?? what is it
Old Feb 6, 2013 | 11:19 AM
ineedhelp92's Avatar
ineedhelp92
Cdr?? what is it
I'm putting a stock turbo off a turbo idi on my non turbo idi I was wondering the CDR valve I think that's what its called is that a very important part or will I be okay with out it. In order for the turbo to hook up I will have to delete it or relocate it.
Old Feb 6, 2013 | 11:35 AM
Phy's Avatar
Phy
The CDR is the diesel version of a PCV valve. It controls how crankcase gasses are sucked from the crankcase and burned. Without it, an engine with lots of blow-by, or over-filled with oil, can suck enough engine oil mist from the crankcase to have a runaway.
The turbo motors have the CDR on the drivers side valve cover.
Old Feb 6, 2013 | 01:47 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Short answer, yes it needs relocated. You will need the intake block off plate where the CDR mounts on the NA engine, and the Valve cover off the turbo engine where the CDR gets moved to.
Old Feb 7, 2013 | 10:30 AM
ineedhelp92
Okay thanks a lot any idea where I could find said valve cover?
Old Feb 7, 2013 | 12:34 PM
hairyboxnoogle
Uhh.. off the truck you got the turbo from would be my first thought. If you cant come up with that one, then youre pretty much SOL. Some have modified the valve cover to make it work. I guess another option would be to use the banks style relocation deal, but you still have to figure out a way to mount it to the intake pre turbo.
Old Feb 8, 2013 | 09:44 AM
ineedhelp92
The previous owner of the truck got the turbo... I'll have to do some fabrication then.
whalebus2112
Dec 2, 2012 08:25 PM
srt35
Jul 12, 2008 06:45 PM
KyleG
Sep 26, 2007 04:59 AM
chris128
Nov 25, 2005 05:33 AM
metalbender
Dec 15, 2002 10:51 AM
