dually wheels - there are different offsets on those!!!
So I got new tires today, and when I got home I noticed the distance between the sidewalls on one side was larger than the other - sure enough, I can put my palm in there all the way to the thumb knuckle on the wide side, and barely my finger tips on the narrow side. Darn! Off come the wheels, looking at the wheel codes - three are 28333, one is 28371, that single one has more dish to it and it's what's making for the extra space... So tomorrow I get to pull the front wheels and check them to see if any is a 28371 code as well, and there are two spares also - yup FML for sure. Hopefully I do get lucky tho and find one more deep-dish wheel cause if I run all 28333s on the rear there is very little space between their sidewalls, way too little for my liking. Anyone know what the backspacing is for the 28333 and the 28371 wheels in inches?
I know one pair of dually rims I have won't go on the inner rear, they hit the brake drums. Work fine on the outside, which is where they are right now, but I have to keep track of them when it goes for tires! Someday I need to do some musical tire and wheel moving and get it back on the original 6 rims again!
on
i scored 5 of mine at one salvage yard from a truck,and had to order my 6th from out of state.
you wouldn't believe the looks,comments,and just plain no clue from every single person i called,e-mailed,or spoke to in person with didn't know this.
everyone told me if its a ford dually rim it will work.some knew about the 2wd/4wd.but no one had a clue there are so many different offsets between them all.
you should have seen peoples faces,or when i called salvage yards ALL over the place if they would please check the inside # after the "Accuride" brand name stamp.
none of these salvage yards knew where to look,and clearly never been asked the question before.
it wasn't easy finding my missing 6th wheel,let me tell ya lol.
powerstroker,
What you don't want is for the tires to touch inside when you are loaded.
That is a sure fired way to overheat the sidewalls and have a blow out, probably both tires at the same time.
Thats why dual wheels are rather limited to what tires they can run.
Also, Accuride recommends minimum dual spacing of 10.75" for the 235/85-16 tires, my wheels are 5.00" outset each for a total of 10.00" dual spacing, so my wheels are 3/4" closer than they should be... And so are yours by the way, but not as bad - for your 225s they suggest 10.20" dual spacing, you got 10.00" so you should be good
As for what I should be running, turns out the correct wheels I need are the 28512 (obsoltete number) Accuride, current model 29578 - they are 16x6 size, 8 on 6.5" bolt pattern, but with 5.35" outset (which would make for 10.70" dual spacing which is perfect). Now where the heck am I gonna find them wheels, that's a whole different story... Or I can just remount the one tire from the 28371 wheel to a 28333 wheel and run some thin spacers between the inboards and outboards and be done with this whole mess!
Not sure if LCAM was doing the same, but I found this on Accuride's site. http://www.accuridewheels.com/lighttruckwheels.pdf
There are a couple gas pipe line welder rigs running around here that used the spacers you would run on a SRW axle to mount dual wheels.
One pair against the hub to get sprring clearance, another pair between the wheels for space between the tires so they can run 325 wide tires as duals.
They are also running another set on the front axle so they can have all six tires the same size.
Good thing those guys make good money, that is a pile of money in spacers before they ever start buying wheels and tires.
And then when they get off road, onboard air with air bags on all four corners for extra clearance with ARB air lockers in both axles.
Does make for a mean looking duallie though.
on
i think that's what id do too lcam.
only other way,would be if you could score dually rims for next to nothing.
the spacers are not to bad.around a hundred bucks or so on ebay i think,last i looked.
i know i wouldn't like dual 235's with mine.-yup 28511's.
are you sure 1/2 will be enough when loaded and tire bulge out a bit?
or you could just join me and run dual 8.9" doughnuts LOL.
