engine goin in finally!!
Old Feb 7, 2013 | 02:48 PM
F-250 restorer's Avatar
F-250 restorer
I'm curious about what gears you have in the rear end? Do you know?
I'm also starting a national movement to get you to port the head.
Old Feb 7, 2013 | 03:05 PM
68cabby's Avatar
68cabby
A national movement haha
I do know. I have 3.25 gears. I would like to eventually..but unfortunately I have to get the truck up and moving out of my friends shop haha
Old Feb 7, 2013 | 03:43 PM
F-250 restorer
This is nothing to be alarmed about. I am simply shocked at the price difference between the Isky valve springs and the Comp springs: $48 as opposed to $138. Yes, I know the Isky springs are double springs.
I'm also surprised that the Comp springs give only 80 psi at the seat, and the Isky, using only the outside spring supplies 120 psi. The Isky 256 or the 262 are not radical cams. Why does Isky sell such a strong spring?
Note: 24 Isky steel keepers cost almost as much as the Comp v.springs. I wondered why the checkout girl was wearing a mask, and it wasn't Halloween.
Old Feb 7, 2013 | 04:37 PM
68cabby's Avatar
68cabby
Maybe just cuz the differences in performance? I'm sure each company matches their springs with their cams so I'm not sure
Old Feb 9, 2013 | 06:57 PM
68cabby's Avatar
68cabby
Well..and is the isky springs your talking about supposed to go with the Mil-A-Mor?
I ask because I was reading on some other posts about how the amount of time the valves are open affect the kind of power.If they open longer with higher lift, then the more horse power you have..but the faster they close then then more torque and bottom end youll have.
Maybe theyre so strong to facilitate the closing of the valve faster to make more bottom end and conserve fuel, hence the Mil a mor?
Old Feb 9, 2013 | 06:58 PM
68cabby's Avatar
68cabby
Also..I watched that vid from comp about the flat tappet break in. It seems like comp likes to say to use acual BREAK IN OIL in the break in. I know some guys just use oil and add a break in additive. Any thoughts?
Old Feb 9, 2013 | 08:51 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I think all three Isky grinds for the 300 recommend the same springs.
The springs don't affect how quickly the valve closes, that's a function of the cam lobe. Other than the obvious keeping the valve closed, the springs ensure the lifter stays on the cam. Lifters bouncing up and down on the cam rather than sliding along the lobe surface would be a bad thing. When you hear the term valve float or floating the valves at high rpm it's a symptom of weak valve springs.
Break in oil is just oil with the break in additive already mixed in. As long as you use a quality oil to begin with then using a bottle of break in additive should be fine.
Old Feb 9, 2013 | 11:11 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
I would beg to differ, here's what my machinist told me: While a break in additive is better than nothing, a full break in oil is best. If an additive is just thrown in it doesn't mix with the oil as well on a molecular level, and the oil and additive "fight" for space on the cam lobe. A proper break in oil is mixed and doesn't have that issue.
A good 30wt break in oil should fit the bill, it is a bit more expensive, but it's worth it.
Just my $0.02
Sam
Old Feb 10, 2013 | 01:55 AM
F-250 restorer
Oh yeah! There has been peace for quite a while on the oil front. Great, let the oil wars break out once again.
I would add that napa sells the Valvoline racing oil with all the additives needed. Good luck.k
Old Feb 10, 2013 | 09:32 AM
AbandonedBronco's Avatar
AbandonedBronco
Comp makes their own break-in oil. I think it was about $10 a quart at O'Reilly last I checked.
Old Feb 10, 2013 | 10:24 AM
BaronVonAutomatc
Just my $0.02
Sam
Are you saying the chemical composition of the oil is changed when break-in oil is manufactured? Because I guarantee you there are no molecular changes occurring - they're just mixing the base oil and ZDDP additive together and bottling it.
Oil and the break-in additive will get thoroughly mixed together and dispersed if a drill is used to prime the oil pump and oiling system for 20-30 minutes prior to start up. Since that should be standard operating procedure for a new engine anyway paying double the price for pre-mixed oil is a waste. But it's not my money, so spend away.
Old Feb 10, 2013 | 05:26 PM
68cabby's Avatar
68cabby
Sorry to start the war again haha
I've heard about priming the engine..but how do i do that? I believe f250 said sometihng about popping the distributor out and using a drill to spin something?
Old Feb 10, 2013 | 06:55 PM
  #28
BaronVonAutomatc
The oil pump is driven by the distributor - if you've ever removed a distributor from a Ford you've probably had to jiggle it around when you reinstalled to seat it on the oil pump drive shaft. There's a tool (kind of like a socket extension) that allows you to use a drill to turn the pump drive shaft to pressure up the oil system and prime the engine before start-up.
Set the engine to TDC on #1, mark the distributor, then prime prime prime for 20-30 minutes. Then quickly install the distributor and fire the engine. You want to allow as little oil as possible to drain back to the crankcase before starting and breaking in the engine after priming the oil system.
Old Feb 10, 2013 | 07:12 PM
  #29
jack orchard's Avatar
jack orchard
F250 is right, with motor completely assembled, pull distributor and using oil pump drive shaft (an old one will do) spin the oil pump in a clockwise direction. You will have to make some sort of an extension so it will be long enough to reach the oil pump. As pressure rises, slowly rotate the crankshaft so that oil is distributed evenly thru the engine. You will be "good to go" when oil is pumped thru each push rod and every rocker arm is lubed. I like to dump a quart of oil on top of the valves, making sure each valve and pushrod is lubed well. Don't forget to lube the rocker arms, and the valve tips. If oil pressure does not rise, something is wrong. Do not start. Find out why. Good luck. ...jack
Otto396
15
Nov 4, 2015 06:52 PM
Gigemags05
May 14, 2015 03:35 PM
parkland
6.4L Power Stroke Diesel
Mar 4, 2012 01:03 PM
Shake-N-Bake
Dec 3, 2003 06:45 AM
