RiffRaff Plenum Inserts
Old Feb 4, 2013 | 08:02 AM
koski19's Avatar
koski19
Hi Guys...Has anyone installed the Plenum Inserts on their early 99 from Clay?
I bought a set and went to install this past weekend and they are too large for my 7.3....I went back to the website to read the description and it doesn't say anything about fitting the early or late 99's...So, if you have installed these on an early 99.....how'd you do it?
Thanks
Jeff
Old Feb 4, 2013 | 08:27 AM
microdevil45's Avatar
microdevil45
Not having an early 99 I can't be 100% on this but I believe the only way you can get those to work is to replace your Plenum's with late model plenum's. Insert link here: Plenums
They changed the size from the smaller ones (early 99) you have to the larger ones (late 99-04)we have. Sorry man.
Old Feb 4, 2013 | 08:40 AM
mueckster's Avatar
mueckster
The plenum inserts were designed for the late '99-03 plenums. AFAIK, there aren't any inserts available to fit the smaller early model ones. To swap to the late model ones, other companion mating parts will need to be upgraded, as well. Those are the parts included in this kit. Riffraff Diesel Performance Parts: - Early 99 Turbo Conversion Kit
Old Feb 4, 2013 | 09:04 AM
koski19's Avatar
koski19
OK.....Thanks for the info....I'll call Clay later for a RA on the parts.
Jeff
Old Feb 4, 2013 | 10:01 AM
microdevil45
Thanks for clarifying. I knew it was something along those lines.
ttttmaxx
Mar 1, 2010 02:07 PM
T8R
23
Dec 20, 2009 09:15 PM
Big Swole
Jan 10, 2008 05:23 PM
ghunt
Oct 24, 2005 02:09 AM
editdog
Jul 11, 2002 08:37 PM
