injector connect not working
Old Feb 1, 2013 | 02:57 PM
mike L's Avatar
mike L
I got a open circuit code on #4. When I put a test light between the injector ground wire and the poss. on the battery. The light doesn't flash with the rpms, while the engine is running. Like the other injectors connectors do. This #4 connecter stays on. Ohms tested #4 its the same as #3, seems ok. But its not like #2, the ohm needle doesn't move. Now what can I try?
Old Feb 10, 2013 | 04:10 PM
LxMan1's Avatar
LxMan1
You need a noid light to check it properly.
Could be a bad wire in the harness or a bad injector driver in the ECM
I have had a couple of Mid 90's ECMs fail, but both of those stuck the injector wide open and dumped raw fuel thru the cylinder. One was a 94 4.6L Cougar and the other was a 94 Mustang 3.8L v6.
Old May 5, 2013 | 09:48 PM
VLUCIAJR's Avatar
VLUCIAJR
DOES A 2000 4.6 HAVE A INJECTOR DRIVER IN ITS PCM????
Old May 5, 2013 | 09:53 PM
JWC 3's Avatar
JWC 3
Yes , the ecm/pcm controlls the injectors .
Fldiesel73
Nov 8, 2016 07:37 PM
c4jlca
Jan 13, 2013 03:32 PM
Chester_field
6.4L Power Stroke Diesel
13
Oct 5, 2012 03:44 PM
99f250craig
Aug 4, 2011 10:24 PM
19704X4F250
1983 - 2012 Ranger & B-Series
Jul 5, 2008 08:53 PM
