PCM Differences
Old Jan 30, 2013 | 10:31 PM
caedo's Avatar
caedo
PCM Differences
Im just curious what the differences are between the VDH4 out of an 02 and a VDH5 out of an 03. I swapped them the other day because i wanted the 02 to have a stock tune (which the VDH5 had) instead of the superchips tune (which the VDH4 has). They both seem to run fine when swapped. Is there even a difference or did they need a new name for the next year?
Old Jan 30, 2013 | 10:55 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
From what you'll notice in the driver's seat, nothing.
Old Jan 30, 2013 | 11:00 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Not a very elaborate answer, but he knows what hes talking about. Anything worth mentioning, he would have. So you should be good to go.
Old Jan 31, 2013 | 12:28 AM
INFRNL's Avatar
INFRNL
I believe anything in the VDH family works with one another. I have VDH5 and sold my old DP chip to a guy running VDH4 and the chip worked just fine.
Nothing to worry about, you're fine.
Old Jan 31, 2013 | 08:31 AM
jeffreyt's Avatar
jeffreyt
I had VDH5 on my last truck, Tex is VDH4 I think. If I recall correctly (and I'm sure Cody will be quick to correct me if I'm wrong) the stock setting on my TS is VDH3, which has run fine in both trucks. Pretty sure they are interchangeable.
Old Oct 24, 2025 | 04:18 PM
Straijor000's Avatar
Straijor000
1st Gear
I accidentally fried my computer with is the vdh4 2c3f-12a650 de I’m trying to us a 2c3f-12a650 df same dpc 462 I accidentally sent power through the ground wire on icp when checking for power and negative wires and truck has no clicking from fuel pump to fuel bowl but can hear fuel hissing in the bowl. Crank no start 2002 ford f 250 7.3 powerstroke 4x4
Old Oct 25, 2025 | 08:23 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I'm not entirely sure what your attempting to ask or convey to us, but you could send your PCM to Diesel Tech Chattanooga and they will either repair it or tell you what your options are.
Good luck to you.
DanielT28
Jul 16, 2015 04:58 PM
Spool&Go
Oct 29, 2014 10:35 PM
sunuvabug
Computer Chips & Tuners
23
Aug 4, 2013 04:56 PM
papadelogan
18
Jul 16, 2009 10:53 PM
Cobratodd
Jun 28, 2006 10:11 AM
