Hey all,
The po of my truck installed an aftermarket temp gauge that runs directly to the coolant temp sensor. The temp sensor is therefor not giving any information to the truck other than to this temp gauge. I can see that the old temp sensor plug is not connected. My question is will this have any effect on how the truck will run?
I ask because of a warm start issue i have had since purchasing the truck. She starts up fine from cold, but after shutting it off after 10 minutes it has a hard time starting back up. Can this have anything to do with my warm start issue?
I used to have a setup like that. I had pulled the oem temp sender and installed an aftermarket sender and gauge. I then just let the old plug hang out.
Your'e correct that it doesn't effect the truck's operation. All that spot does is send a signal to a gauge. The OEM setup is the same.
I'm not saying the ECT is the problem. It may be something else like an ignition module. What I would do is pull the codes from the computer and see what you get. This web page gives some good procedure: Fuel Injection Technical Library » How To Run a Self-Test
If counting sweeps and beeps and lights is tough for you (like it is me, I hate it) try to get one these readers. They count for you and display the code: Innova 3145 Ford Digital Code Reader
Hope this helps and post back with your codes! Tons of guys on here who know a great deal about what usually causes certain codes. Posting codes nearly always gets you an answer back!
Thanks for the help!
The truck has been sitting for about six months because I'm busy with school and dont always have time to work on it. That being said, at the end of the summer i did pull some codes (or at least i tried, i do plan on ordering a reader) and i believe the code that showed up was 118. I checked my haynes manual and it said:
118-ECT sensor circuit open
118-ECt sensor circuit below max voltage or reads 40.
I checked in the back of the book for more information on the ECT but there are no tests for it. Is there any test i can perform or am i better off spending 30$ and buying a new one. If so does anyone know a good site to order from? (Canada)
If this ^^^ is indeed correct - and the error codes you've supplied seem to indicate that it is - this is a very bad idea. The PCM needs an ECT input to function correctly. A temp gauge is optional. ECT input, not so much for proper engine function.
Hook the ECT back up as a first priority. Then figure out how you can hook up the gauge at your leisure.
The ECT is connected, what is not connected is the coolant temp sending unit located in the intake manifold, near the distributor.
Both sensors are near the distributor on the 5.0, the ECT is mounted in top of the thermostat housing and the gauge sensor is mounted in front of #5 fuel injector. It's OK to unplug the gauge sensor but not the ECT, but also note its common to get a false ECT code if the engine is not warmed up before doing the test.
Thanks for the advice. Ill only be able to work on the truck again next weekend so ill try pulling some more codes then.
If the signal is good at the stated temperature vs. voltage output (or resistance) then you may have a wiring problem preventing the signal from making it to the PCM (computer). A faulty ECT could very well cause your warm start issue.
