temp sensor / torque pro/ scan gauge
Old Aug 20, 2018 | 08:11 PM
MONAVIERONJON's Avatar
MONAVIERONJON
might have a bad temp sensor, dash doesnt read anything. I do get -40 in the middle of Florida summer heat on torque pro. Scan gauge is crazy in the 225 range, no error codes. I have a brand new sensor , about to install it. what else could it be?might try hitting it with a hammer..... Thankx In Advance
Old Aug 20, 2018 | 09:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be the wiring between the PCM and the sensor.
Old Aug 21, 2018 | 01:33 AM
Silverhks's Avatar
Silverhks
There is no connection between the PCM and the coolant temp sensor. It only reports to the dash.
This means no OBD device will give you a coolant temp only whatever it uses to show no signal.
From what I have read hear everyone just uses the oil temp.
Old Aug 21, 2018 | 06:47 AM
Walleye Hunter's Avatar
Walleye Hunter
Only models with manual transmissions give coolant temp readings so if you have an automatic transmission your scanner cannot read them. Hopefully a new sensor will solve your gauge not reading. OEM only on sensors, others don't play nice with our trucks.
Old Aug 21, 2018 | 01:18 PM
MONAVIERONJON
its a 4r100, and i have a new motorcraft sensor. might just swap out gauge clusters to see if the gauge itself isnt bad
Duct Tape Racing
Feb 4, 2018 06:22 PM
Oldanvilyoungsmith
Aug 30, 2016 06:43 PM
Notpilbrisk
35
May 23, 2016 01:09 PM
RebusCom
Sep 21, 2013 04:28 PM
caseydudem
21
Jan 15, 2008 07:14 AM
