Sponsored by: Auxito
codes....
Old Jan 24, 2013 | 05:36 PM
bcaughhorn's Avatar
bcaughhorn
codes....
I just checked my computer I have a couple codes
P0453 evap emission system pressure sensor/ switch high
P0232 fuel pump secondary circuit high
C1303 right front isolation clamping circuit..
P0305 cylinder 5 misfire.
I changed the fuel pump 2 days ago and the coil on cyl 5.
Can somebody point me in the right direction
Old Jan 24, 2013 | 07:48 PM
Bluegrass 7's Avatar
Bluegrass 7
If you just changed the fuel pump, the two codes 232 and 453 are related to the pump work. Likely the plugup connector has some opens for those circuits.
The 305 is seperate. Did you use grease on the boot so it 'find' the plug tip and not get hung up? If you don't feel the missfire the code is old history.
The C code you just have to chase down.
Good luck.
Nashterbater
May 30, 2016 10:31 AM
jurban
Jun 2, 2012 09:29 AM
Mike Norwood
Mar 23, 2009 09:19 PM
dadrich67
1978 - 1996 Big Bronco
15
Feb 20, 2008 07:03 PM
dougas
Aerostar
May 7, 2003 02:34 PM
