do I need to replace all this?
Old Jun 2, 2012 | 09:09 AM
jurban's Avatar
jurban
1989 f150 300 5 spd. pulled codes:14 engine rpm sig fault, 31 egr position sensor, 41 oxygen sensor, 67 neutral switch, 87 fuel pump circuit, and 96 fuel pump secondary circuit failure.
The symptoms are CEL flashes intermittently or sometimes stays on, I get a bucking or a shutter around 2000 rpm, mainly when the engine is warm. Ive been driving it and it always starts and takes me 25 miles to work but sometimes I feel that the sputtering is going to leave me stranded on the side of the road. Any ideas?
Old Jun 2, 2012 | 09:22 AM
x_man586's Avatar
x_man586
There are ways to test the individual components and it could be that one bad part is causing multiple error codes. I wouldn't just start replacing stuff because you might end up wasting money. Do you have a chilton or Haynes service manual?
Old Jun 2, 2012 | 09:23 AM
ctubutis's Avatar
ctubutis
In general, the persistent CM codes should be dealt with first, the most critical of which are listed first in line.
Despite that, what I see there is an apparent fuel supply problem... do you have two pumps? like, a low-pressure pump in the tank(s) and a high-pressure pump located closer to the engine? It is not uncommon for an in-tank pump to burn out, leaving the high-pressure pump to do the entire job. I would begin there - make sure all your pumps are working - and fix that issue, clear the codes and see what codes come back and go from there.
The EGR position sensor is totally unrelated to the fuel supply and is likely in need of attention independently of the fuel supply.
Might remove and clean the electrical connections to anything connected to the computer, make sure there aren't any exposed/frayed/shorted/burned wires and stuff is in serviceable condition.
The computer is just an aid in diagnosing things and isn't a substitute to troubleshooting on your part.
Old Jun 2, 2012 | 09:29 AM
Conanski's Avatar
Conanski
The source of code 14 could leave you stranded that is the PIP module inside the distributor, so that or the whole distributor should be changed asap.
The other codes aren't as critical and you can completely ignore the fuel pump codes if the truck has dual tanks, those codes are often triggeded when switching back and forth. An EGR problem can produce drivability issues so I'd suggest you look into that next, you could simply have a cracked vacuum line but the position sensor on top of the valve could be bad too. Code 41 is not really telling you the O2 is bad, it's saying the engine is lean and that could be because of the other problems so fix those first, clear the codes and drive it for a week to see if any come back.
Markrichter
Jan 4, 2016 11:30 AM
jungles82
32
Nov 14, 2010 09:51 PM
glue factory
1978 - 1996 Big Bronco
Jun 1, 2009 12:15 PM
Monty06
Bronco II
Jul 21, 2005 12:01 AM
crystalmcdowall
1997 - 2003 F150
Jul 22, 2004 12:03 PM
