alternator wiring question
Old Jan 24, 2013 | 12:58 PM
c_silva88's Avatar
c_silva88
ok so i have an 84 f150 with an external regulated alternator and i have a fairly new internally regulator from my parts truck. i know it'll physically swap in and i have all the wiring to go with the new one. i was wondering if all i had to do was plug the harness with the new alternator in and its good or am i gonna have to rewire the plugs for it to work properly?
Old Jan 24, 2013 | 02:02 PM
Gary Lewis's Avatar
Gary Lewis
You need to get familiar with the stickies at the top of the forum's page, and figure out how to search. In the stickies there's a thread about tips and tricks, and in it there's this one which has lots of answers to your questions.
Old Jan 24, 2013 | 04:55 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm assuming this is a 2G alternator. (external fan, internal regulator)
If so, I would say it is not an 'upgrade' for the better.
These plugs are problematic and the orange/black wiring is suspect too.
There is really only 5A more available than the 1G you already have (75 vs 70)
And the stud mounted charge cable of the 1G is much safer.
Old Jan 25, 2013 | 05:06 PM
Franklin2's Avatar
Franklin2
I agree, if your newer alternator has the two black/orange wires coming out of a slide connector(the alternator has no large output lug with a nut on it) I would not put that in your truck.
Old Jan 25, 2013 | 10:06 PM
joshofalltrades's Avatar
joshofalltrades
better yet would be to go with a 3g alternator from the junkyard - search about that too, plenty of info here
Old Jan 26, 2013 | 09:40 AM
Franklin2's Avatar
Franklin2
I would stick with the old style myself. Solid performers that had enough output unless you start adding winches, electric fans, a bunch of off-road lights, etc. I even used this alternator with a snowplow, and it worked ok IF I turned the idle up on the engine when I was using the plow.
Old Jan 26, 2013 | 10:06 AM
c_silva88's Avatar
c_silva88
thanks for all the replies i actually found a 100 amp 1g that i had from my old diesel(big case style with ring terminals for the power and ground) which i swapped in. i ended up using 4 gauge wire with a 175amp fuse to hook it up to the battery and using the original regulator.
Old Jan 26, 2013 | 10:09 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Good Job!
At least you don't have to deal with that melting plug and all the problems it brings.
Welcome to the forum.
patjr_45
Mar 15, 2021 06:57 AM
nilzlofgren
Nov 15, 2015 05:24 PM
seagiant
Mar 18, 2015 07:57 PM
59Fguy
May 23, 2004 08:40 AM
Cowboy_tx
Oct 10, 2002 02:19 PM
