Navigator 2005 THX Bypass AMP
Hi guys After a couple search I found out my 2005 Navigator with THX Audio system NAV I cannot power on the amp for Aftermarket Radio, once the NAV is too old I'm working on a project to install a Tablet on my truck and I need install a Aftermarket Radio do use as Audio system for the Tablet, once there is not Harness wiring kit for THX 2005 only 2007 and UP I dont want re wiring speakers or replace Them, I just unplugged 2 Conector from the THX AMP one 24pin Ford and 16pin , I need help to find which one are the speakers wires and the SUB so I can put a NEW AMP and go from There here is the pic for the connectors
Thanks
Manny
http://i1354.photobucket.com/albums/...ps63effbfc.jpg
http://i1354.photobucket.com/albums/...ps81a3a9ac.jpg
http://i1354.photobucket.com/albums/...ps3178f958.jpg
http://i1354.photobucket.com/albums/...pse96aac8f.jpg
Thanks
Manny
Here's some wiring diagrams from Autozone's site.
http://repairguide.autozone.com/znet...3f802366cc.gif
http://repairguide.autozone.com/znet...3f802366cd.gif
http://repairguide.autozone.com/znet...3f802366ce.gif
http://repairguide.autozone.com/znet...3f802366cf.gif
http://repairguide.autozone.com/znet...3f802366d0.gif
http://repairguide.autozone.com/znet...3f802366d1.gif
http://repairguide.autozone.com/znet...3f802366d2.gif
http://repairguide.autozone.com/znet...3f802366d3.gif
http://repairguide.autozone.com/znet...3f802366d4.gif
I'm working replace the Original DVD Screen on Back...Going to install a 15" motorized and i want know if you have the wiring diagram for the harness the connect the OEM DVD Screen
Thanks Buddie
Hooking up an amp.
It is a 2006 Lincoln Navigator with the THX audio system. Under the rear cup holder in back is the wires for the stock subwoofer there is a clip with four wires a black wire with a white stripe, a black wire with a green stripe, a solid green wire, and a purple wire. I want to run the LOC here but am not sure if the amp is before this point or not.And not sure of what wire is what. I have searched and searched for a diagram or codes for the wires and there is nothing. Nothing useful at least.
The diagram shows the subwoofer has two speakers in it. It also shows these wires have a shield of some sort around them. It does not designate the two subwoofers as left and right, it numbers them #1 and #2.
#1 subwoofer + is the solid green wire, #1 subwoofer - is the solid purple wire.
#2 subwoofer + is the black/lightgreen stripe wire, #2 subwoofer - is the black/white stripe wire.
Layson
1999 to 2016 Super Duty
21
03-21-2014 11:19 AM
