Navigator 2005 THX Bypass AMP
Old 01-20-2013, 09:19 PM
Manuel Loureiro's Avatar
Manuel Loureiro
Manuel Loureiro is offline
Hi guys After a couple search I found out my 2005 Navigator with THX Audio system NAV I cannot power on the amp for Aftermarket Radio, once the NAV is too old I'm working on a project to install a Tablet on my truck and I need install a Aftermarket Radio do use as Audio system for the Tablet, once there is not Harness wiring kit for THX 2005 only 2007 and UP I dont want re wiring speakers or replace Them, I just unplugged 2 Conector from the THX AMP one 24pin Ford and 16pin , I need help to find which one are the speakers wires and the SUB so I can put a NEW AMP and go from There here is the pic for the connectors
Thanks
Manny
http://i1354.photobucket.com/albums/...ps63effbfc.jpg
http://i1354.photobucket.com/albums/...ps81a3a9ac.jpg
http://i1354.photobucket.com/albums/...ps3178f958.jpg
http://i1354.photobucket.com/albums/...pse96aac8f.jpg
Old 01-21-2013, 07:16 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
Old 01-21-2013, 04:22 PM
Manuel Loureiro
Dave Thanks So much this will help a lot...
Take care
Old 02-03-2013, 09:02 AM
Manuel Loureiro
Hey Dave Again Want say thanks you your help this is the first results of my building and because you send all the wiring diagram it helped me a lot Really Thanks
I'm working replace the Original DVD Screen on Back...Going to install a 15" motorized and i want know if you have the wiring diagram for the harness the connect the OEM DVD Screen
Thanks Buddie
Old 02-03-2013, 12:18 PM
Franklin2's Avatar
Franklin2
It's probably in the same section of diagrams that I got. I got them from Autozone's site. Go to their site, register yourself, and then plug in your vehicle. Click on "repair guides" and then click on "wiring diagrams" Then click on "entertainment systems".
Old 02-03-2013, 07:59 PM
Manuel Loureiro
Thanks I Did that....
but once I Bypassed the Factory AMP so nothing works on DVD harness, I was able to get all the wires I Need from the Sunroof motor just finished
thanks
here is how it come out
Old 05-23-2018, 10:22 PM
Drock1973's Avatar
Drock1973
Drock1973 is offline
Rear subwoofer wires.
There are 4 wires going to the subwoofer trying to run a line out converter. Not sure what wires are what. 2 wires are solid and 2 are striped. Can some one give me a diagram or at least tell me what each wire is for.
Old 05-24-2018, 04:05 PM
Franklin2's Avatar
Franklin2
What are you working on? Year, model, and what system?
Old 05-24-2018, 07:15 PM
Drock1973's Avatar
Drock1973
Hooking up an amp.
It is a 2006 Lincoln Navigator with the THX audio system. Under the rear cup holder in back is the wires for the stock subwoofer there is a clip with four wires a black wire with a white stripe, a black wire with a green stripe, a solid green wire, and a purple wire. I want to run the LOC here but am not sure if the amp is before this point or not.And not sure of what wire is what. I have searched and searched for a diagram or codes for the wires and there is nothing. Nothing useful at least.
Old 05-24-2018, 08:04 PM
Franklin2's Avatar
Franklin2
The diagram shows the subwoofer has two speakers in it. It also shows these wires have a shield of some sort around them. It does not designate the two subwoofers as left and right, it numbers them #1 and #2.
#1 subwoofer + is the solid green wire, #1 subwoofer - is the solid purple wire.
#2 subwoofer + is the black/lightgreen stripe wire, #2 subwoofer - is the black/white stripe wire.
Old 05-24-2018, 08:14 PM
Drock1973's Avatar
Drock1973
Thank you. I hooked up the LOC to the striped wires and got nothing. But when I tried the green and our purple my amp and subs came to life. Thanks again.
Peace2Peep
10-01-2023 04:08 PM
Steve Christensen
1947 and Older Ford Trucks
03-28-2016 07:23 AM
Layson
1999 to 2016 Super Duty
21
03-21-2014 11:19 AM
pdombrowicki
01-23-2014 11:25 PM
pdombrowicki
6.7L Power Stroke Diesel
151
01-23-2014 09:16 PM
Quick Reply: Navigator 2005 THX Bypass AMP
