Do i have a voltage issue?
Old Jan 20, 2013 | 10:40 PM
bismic's Avatar
bismic
10.7 is fairly normal - especially in the cold weather. Below 10 us NOT normal. Sounds like you just needed the charge, but I would watch it fairly close.
Old Jan 20, 2013 | 11:19 PM
BLADE35's Avatar
BLADE35
Agree with this^^^
And if you just Installed New Dura last Gold top Batterys they take some time to charge
I installed Gold Tops a Couple months Back they charged alot that first Day and half They Shure Did NOT Come Fulley Charged
So I think that might be what your seeing earlier But sounds like you did a Fair amount of driving so they should be Charged up good Now
Next time I get New Batterys I will Hook them up to a Charger and TOP Them Off before I hook them up to the Truck
Old Jan 21, 2013 | 02:33 AM
Yahiko's Avatar
Yahiko
FTE Remembers
New batteries need to be charger before you really put them into
service. If you have the time call them before you go pick a new set
and have them charge them for an hour or two before you pick them up.
Battery health care data
http://www.trojanbattery.com/pdf/trj...usersguide.pdf
http://www.scubaengineer.com/documen...ing_graphs.pdf
The 12volt Side of Life (Part 1)
Battery Performance Characteristics - How to specify and test a battery
OK I do have a sort of
Any one notice that the SGII us about 0.5V off what you read with a
DMM at the battery post? My SGII reads the 0.5V lower than my meter.
cable are clean. I am about ready to do a drop test on mine just to see
if I can find the problem if there is a problem even.
Sean
Old Jan 21, 2013 | 06:02 AM
MC5C's Avatar
MC5C
Keep in mind that the Scangauge is not actually reading a voltage at all, it's being sent a digital code by the CPU that represents the voltage measured by a sensor somewhere. Same with FICM voltages. It's highly likely that the voltages don't bop about the way the sensor says they do, but that some other algorithm in the computer code is causing the variation. I put in an Autometer voltmeter and just look at it once in a while.
Brian
Old Jan 21, 2013 | 02:07 PM
Yahiko's Avatar
Yahiko
FTE Remembers
The kicker to that is unplug the SGII and plug the Snap On in and it up by 0.5V
That's not right.
Sean
Old Jan 21, 2013 | 07:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sean
There is always some amount of voltage drop in the wiring harness. When you're talking several dozen feet of 12-14 gauge wiring you'll have less at the end of the drop than at the source.
I see about .2-.4 voltage difference between the OBD port and the power port compared to the battery posts.
Josh
Old Jan 21, 2013 | 09:51 PM
BLADE35's Avatar
BLADE35
yes there is ALWAYS a Voltage drop
The Longer the Wire the BIGGER the Voltage DROP
xaviar
May 8, 2015 07:01 PM
Whisker
Nov 14, 2014 05:21 PM
bigred66
Nov 13, 2012 03:09 PM
zackclan
35
Aug 22, 2012 07:41 AM
TJK1
Dec 1, 2011 10:58 AM
