Something new from BPD
Old Jan 18, 2013 | 09:05 PM
snorindad's Avatar
snorindad
Saw this on facebook. Not sure what aplication it is for. I was wondering if anyone else has seen this or knows anything about it.
https://www.facebook.com/#!/photo.ph...type=1&theater
Old Jan 18, 2013 | 10:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
So the new cooler keep the original oil filter somehow.
Hmmm....
Josh
Old Jan 18, 2013 | 10:53 PM
daddykitty's Avatar
daddykitty
wonder how much cheaper it will be?
Old Jan 18, 2013 | 11:05 PM
karlsdash's Avatar
karlsdash
haha finally realized what you were talking about... im going to bed and gonna put the scotch away lol
Old Jan 21, 2013 | 08:09 PM
togie's Avatar
togie
Doesn't seem to be a bad system but by the time I have to add the cold weather option too it a little too pricy for most of my customers
Old Jan 21, 2013 | 08:13 PM
69cj's Avatar
69cj
Correct my ignorance, an external oil cooler set up??
Old Jan 21, 2013 | 08:17 PM
daddykitty's Avatar
daddykitty
from what it looks like to me is that the oem filter/housing will stay in the current location. From the look of the hoses and evap coil that goes with it, i am thinking the coolant will not be the only thing cooling the oil...so a liquid to liquid to air heat exchanger...only a guess from looking at pictures
Old Jan 21, 2013 | 08:27 PM
Bullitt390's Avatar
Bullitt390
I don't think that new cooler design uses the factory oil cooler and uses transfer slots to direct the oil into the oil lines to the external cooler.
Josh
Old Jan 21, 2013 | 08:32 PM
daddykitty's Avatar
daddykitty
Josh
zoom in and have a look at the billet ports where the oil cooler would normally poke thru the oem cover. It looks like, and again i am guessing here, but the the oil will not only be cooled by coolant but also by air. No?
Old Jan 21, 2013 | 08:40 PM
Bullitt390's Avatar
Bullitt390
Isn't that where the new hose fittings bolt on? You're talking the two ports at the rear of the cover inline with the EGR coolant outlet right?
It could go either way I suppose, but the kit shows all the parts and gaskets, even an OEM filter, but no OEM oil cooler in that kit.
Josh
Old Jan 21, 2013 | 08:54 PM
daddykitty's Avatar
daddykitty
Josh
im thinking you might have to reuse/replace your own cover and oil cooler might be an option
Old Jan 21, 2013 | 09:34 PM
Bullitt390's Avatar
Bullitt390
Definately have to reuse the oil filter base.
You know what would make a good cooler is to adapt the EGR cooler into an oil cooler. It would be similar to the 7.3 diesel then, especially the early style cooler or the BPD cooler.
Josh
Old Jan 21, 2013 | 09:38 PM
daddykitty's Avatar
daddykitty
i know very little of the 7.3, and even less on the 6.0...lol
Old Jan 21, 2013 | 09:50 PM
Bullitt390's Avatar
Bullitt390
When you look at the 6.0 EGR cooler...
Then look at the 7.3 oil cooler...
I see possiblities...
Josh
Old Jan 21, 2013 | 10:00 PM
daddykitty's Avatar
daddykitty
josh....you seriously need to get out more
