Drip, drip, drip Diesel
I have a fuel leak at the top of my engine. I have searched the threads on here, and found no definite answer to my question. It appears to be coming from some sort of sensor, screwed into the bottom of the fuel filter housing, at the back. It has only one wire going to it, and looks to be a PIA to change. Could what ever that is leak? Its hard to see for sure, its buried under everthing. But i see a drip landing in the pan, right under neith it, with the enging running. What is it called? So if that is it, I could order one. And if that is the case, what would be a good idea to replace while I have it all exposed? Its a 95 F350 4x4, 4 door, 7.3 Power Stroke. And thanks for the help, in advance.
Stephenn95
04-19-2015 01:01 PM
Hussler
13
12-19-2007 05:54 PM
