Fuel leak.. Argh
Old Nov 25, 2015 | 02:37 PM
green_95's Avatar
green_95
Fuel leak.. Argh
Thought I had my fuel leak solved on my 7.3 . it was filling the valley and leaking pretty good when i would park. Found out my fuel pump was leaking from the weap hole. Replaced the pump and put newlines on it and its still leaking. Not near as badly but it's still a leak. Takes a few days to fill the valley up. Could it be my fuel filter restriction sensor? I noticed where the plastic part is crimped to the metal part it seaps around it. It doesn't drip but just seaps unless it drips while your driving it. I ordered one from diesel o rings. If this doesn't fix it I may just buy a complete fuel bowl from diesel o rings.
Old Nov 25, 2015 | 02:44 PM
Hussler's Avatar
Hussler
Yes, the fuel restriction sensor tends to leak with age. Went through the same thing. Replaced the fuel pump and hoses but still smelled fuel. Turned out to be that sensor.
Hint: Don't over tighten the new sensor as you can crack the housing.
Old Nov 25, 2015 | 02:55 PM
Jarrett Campbell's Avatar
Jarrett Campbell
I second that warning! Cracked my fpr installing a fuel pressure gauge.
....you could always go e fuel! I love my system
Old Nov 25, 2015 | 02:57 PM
green_95's Avatar
green_95
What's this "e fuel" you speak of?
Old Nov 25, 2015 | 04:26 PM
Hussler's Avatar
Hussler
Eliminates the fuel bowl, lift pump and uses an electric fuel pump. Some build their own and some purchase a ready made kit.
Old Nov 25, 2015 | 04:45 PM
Jarrett Campbell
I ended up getting a kit. I don't have the experience or the time to piece it together. The one I went with was very easy to install with excellent step by step instructions and fantastic customer service.
Bottom line: diy is cheaper but wasn't in my comfort zone.
The kit I went with:
Strictly Diesel 94-97 E-Fuel
mudrat025
Jun 27, 2013 08:06 PM
Tater50
37
Dec 25, 2010 07:19 PM
granny_rocket
Dec 22, 2010 05:23 PM
fridgeddiesel
36
Jan 3, 2009 08:40 PM
threejacks
Oct 16, 2005 10:16 PM
