Front Grille Cover
Old Jan 17, 2013 | 06:31 PM
Will Bite's Avatar
Will Bite
Perhaps the computer might still believe the engine isn't fully
"warmed up" and you might have lower fuel mileage? That was my main reason for doing it but well see how much hotter it runs.
Old Jan 17, 2013 | 06:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe to do the delta test, the OAT must be higher than -20!!!! Winter in Idaho isn't a fair test! LOL
Old Jan 17, 2013 | 07:00 PM
Will Bite's Avatar
Will Bite
http://images.ford-trucks.com/forums...ies2/thumb.gif agreed ! So we cant check anything on the trucks in the winter because they don't get to operating temperature.
Old Jan 17, 2013 | 07:27 PM
cartmanea's Avatar
cartmanea
Originally Posted by Will Bite
But running down the road 20 miles. ECT 188, EOT 198. How can my deltas be so far off now but in the summer within 3 deg ? I was told that operating temp. was 190 to 210. If I cant get to operating temp. how can I check them? I'm not trying to be argumentative I just thought the temps should be at-least in the 190s.
Flow through the oil cooler could be reduced when the thermostat is closed. 10 degrees isn't anything to worry about.
Old Jan 18, 2013 | 09:31 AM
Courtney Williams's Avatar
Courtney Williams
I guess as long as its not hurting anything, there are too many variables going on here right now.. the 6 degree temps in Boise, and a new FICM which I hear with the new flash already drops the MPG. I am getting about 2 less than I normally was.. I just got my SGII so I am trying to figure out what my truck is supposed to do and what it is doing. Thanks for all the help.
Old Jan 18, 2013 | 10:29 AM
FordBlueHeart's Avatar
FordBlueHeart
Courtney, my feelings are that $23 for a new OEM thermostat are well worth it. I have just received updated strategies for the PCM, TCM, and FICM. My truck is getting better fuel mileage, runs smoother and ECT is running closer to the magical 192*, but not quite there. 185*-189*.
Air temperature is 13*F here.
Old Jan 18, 2013 | 10:44 AM
Courtney Williams
Well I will get one ordered up today then. I will have a chance to run it hard this weekend with a load on steep grade. I'll watch and see if it jumps up there then.
Old Jan 18, 2013 | 11:04 AM
FordBlueHeart
I also replaced my ECT & EOT sensors to make sure I was getting the proper readings. You don't need to do that, but it reassured me that I wasn't getting false readings. Now I have spare sensors!
Old Jan 18, 2013 | 11:11 AM
Courtney Williams
What about the TFT sensor? That was seems to be off the most. Pretty easy change?
Old Jan 18, 2013 | 11:20 AM
FordBlueHeart
I haven't worried about mine. No towing until this summer for me. Hopefully someone jumps in and answers that for you. My temperature has never been above 160* so far.
Old Jan 18, 2013 | 11:22 AM
Courtney Williams
OK, Mine is hanging in the 145* range. Blades said they are a geap fix.
Old Jan 18, 2013 | 12:32 PM
Will Bite's Avatar
Will Bite
One way down. Truck ran 192-194 with EOT at 196-198 all 150 miles cruise set at 70. Outside temp was 19 when we left and 25 when we got there.
landscapeguy
6.2L V8
16
Jan 1, 2018 10:21 PM
5. Slow
21
Jan 6, 2011 11:17 PM
yoslick
Jan 29, 2009 09:03 PM
superduty4x4
17
Oct 28, 2008 01:25 PM
golfboy17
Nov 13, 2003 04:09 PM
