Front Grille Cover
Old Jan 17, 2013 | 01:29 PM
Will Bite's Avatar
Will Bite
Front Grille Cover
Well see how it works. Changed thermostat in October and now truck wouldn't get above 188 in this cold weather. So I made some out of old siding I had sitting in the garage. I don't think it turned out to bad.
Old Jan 17, 2013 | 01:31 PM
Will Bite's Avatar
Will Bite
Would have been nice to have some BLACK zip-ties.
Old Jan 17, 2013 | 02:04 PM
Courtney Williams's Avatar
Courtney Williams
How cold is it there? Mine wont get over 180 eaither, and even getting it there is a challange right now. I prob need a new thermostat though.
Old Jan 17, 2013 | 02:18 PM
Will Bite's Avatar
Will Bite
Its 33 now. But driving about 20 miles it will go to 190-192 then drop back down to 188 or so. I just replaced mine before winter. I have heat just don't think truck should run that cold. In summer it runs 192-196. Going on a 150 mile trip tomorrow so Ill report back on what it did.
Old Jan 17, 2013 | 03:24 PM
IABill's Avatar
IABill
Wink
I did one of these:
Cabela's: Winter/Summer Truck Grille Covers
Price seemed good and it comes with a summer bug screen.....
Old Jan 17, 2013 | 03:48 PM
Will Bite's Avatar
Will Bite
I thought about that but my way was little cheaper.:-) Well see how it does.
Old Jan 17, 2013 | 04:19 PM
cartmanea's Avatar
cartmanea
There's nothing wrong with it running at 188, that's what the thermostat is designed for.
Old Jan 17, 2013 | 04:33 PM
Misky6.0's Avatar
Misky6.0
I ordered one of these and got it yesterday... plan to install it this
weekend, but I'm gonna go to the local HW store and get "screw on"
snaps. This was also the cheapest place I found, took 3 weeks and it
comes from Canada but I like it..
Around town 10-15 minutes drives don't get the EOT up to temp, the ECT goes up no problem.
My BPD oil cooler works too good unless it's 75+ with the A/C on while on the highway.
Fia Winter Front & Bug Screen Combo | Take 20% Off
Old Jan 17, 2013 | 04:47 PM
Will Bite's Avatar
Will Bite
I guess I dont understand what is the normal operating temperature ? Why do I have a 192 thermostat if it never gets to 192. In the summer my ECT and EOT are 3 degree apart in the winter I get EOT of 198 and ECT of 188.
Old Jan 17, 2013 | 05:00 PM
cartmanea's Avatar
cartmanea
A little still gets by the thermostat when it is closed, but those numbers are perfectly acceptable.
Old Jan 17, 2013 | 05:23 PM
Will Bite's Avatar
Will Bite
How do you check your deltas in the winter ?
Old Jan 17, 2013 | 05:41 PM
cartmanea's Avatar
cartmanea
I would do it after the vehicle is fully warmed up and after running down the highway a while at steady state, just like other times of the year.
Old Jan 17, 2013 | 05:48 PM
Courtney Williams
So what does it do when it doesn't get over 180, stays around 175-179..
Old Jan 17, 2013 | 06:11 PM
Will Bite's Avatar
Will Bite
But running down the road 20 miles. ECT 188, EOT 198. How can my deltas be so far off now but in the summer within 3 deg ? I was told that operating temp. was 190 to 210. If I cant get to operating temp. how can I check them? I'm not trying to be argumentative I just thought the temps should be at-least in the 190s.
Old Jan 17, 2013 | 06:13 PM
Misky6.0's Avatar
Misky6.0
Assuming you are asking what happens engine-wise if the EOT/ECT temp
never gets to ~188-190..
Perhaps the computer might still believe the engine isn't fully
"warmed up" and you might have lower fuel mileage?
188 is about the same as 190. Don't be confused by the digital value appearing
to be more precise than the old analog gauge. 170-175 is too low.. 188 is completely normal and
what I get much of the time for ECT. When I stop at a light it'll go to 192 briefly, the beauty
of airflow/thermostat and analog to digital conversion....
