Pull and Clean Turbo, help!
Old Jan 17, 2013 | 01:09 PM
HunerdProof1371's Avatar
HunerdProof1371
Can anyone point me in the direction of some very detailed instructions on how to remove and clean my turbo? What are some common mistakes and the consequences of when doing this? Just got off the phone with a shop and they quoted me $700 to do it, no way I'm spending that much if I can learn how to do it myself.
Old Jan 17, 2013 | 01:25 PM
mustang_309's Avatar
mustang_309
Check out srmastertechs YouTube videos, very helpful http://m.youtube.com/#/watch?v=lM3dWI76cZk&feature=relmfu
Old Jan 17, 2013 | 08:51 PM
RideDiesel88's Avatar
RideDiesel88
Please dont pay that much! Ive pulled my turbo a few times to clean, its a breeze. Its always good to learn something too. Getting it out is gunna be a pain, you really gotta want it. Once the bolts are out, get out a long pry bar and pop it up and off the pedastal. Buff the unison ring contact surface and unison ring until its stainless shiny steel! A lot of people use a little antisieze on the vane pegs but i dont.. ive had it lock up. Before you separate the turbo, see where the two halves of the turbo meet and tap a mark on both halves with a chizzle so you can line them back up when reassembling. After you get it apart take a pic of the position of the vanes. Once you get it apart you can really see how it works, with the actuator n whatnot (its gunna dump some oil so put it on a pan). The pin on the actuator lines up with a hole on the unison ring. Just make sure all the carbon is out of the turbo before putting it back in. You dont wanna go back in in a couple months. A dremel with a few good buff pads will get er done.
RideDiesel88
SRmastertech has a lot of good videos on these trucks
Old Jan 17, 2013 | 10:34 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Vane posts.
I was using a drill to clean around the posts. (cleaning pad attached) Pad got wedged between a post and the side of housing.
SNAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Broke a post right off.
New turbo!!!!!!!!!!!!!
Be careful around the posts. Don't use a drill!!!!
Will I clean a turbo again? Yes.
But really, my turbo was rusted, and the rust had eaten at the post which made it weak to begin with.
The turbo can come out with out the alternator needing to be removed. Do disconnect the batteries.
Old Jan 18, 2013 | 12:39 AM
HunerdProof1371
Seems like everyone has used a power tool to clean it, is it even doable by hand with something like a Brillo pad or a gun cleaning brush? That's the idea I had in my head, was going to use gun cleaner-lube-protectant.
Old Jan 18, 2013 | 01:36 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Just pick a size that won't get stuck between the post and anything.
Myself I would use a media-blastting with walnut shell.
Sean
run6.0run
Jan 24, 2016 06:39 PM
nmclella
Feb 16, 2014 07:37 PM
KRDiesel
Apr 13, 2010 03:10 PM
silly34
Jan 20, 2010 12:41 PM
wb6anp
Feb 26, 2008 11:49 PM
