Tachometer gone crazy!
Old Jan 17, 2013 | 11:28 AM
87straightsix's Avatar
87straightsix
Ok. Since I received some great help from my fellow ford truck enthusiasts I have another mystery. Recently purchased an 87 f250 4x4 inline six and the tach is not reading correctly. Would anyone know why? At idle its pretty close reading about 800 RPM, but when accelerating, it wraps all the way to red line, when in reality probably around 2500-3000 betweeen shifts. All ignition/coil/distributor wiring seems to be all good and it is an original tach that came with the truck. Any ideas would be helpful!
Thanks guys!
Old Jan 17, 2013 | 12:58 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Often an erratic tach is symptomatic of a failing PIP or TFI, but usually it's more of a "bouncing" behavior than an "over-achieving" tach. Maybe your tach secretly wants to be attached to a 20,000 RPM red-line F1 engine?
Any way, don't eliminate failing ignition components as a possibility, but it doesn't seem like the typical failure symptom.
Old Jan 17, 2013 | 01:14 PM
88n94's Avatar
88n94
I'm guessing your tach is just basically shot. The tach in my '88 won't drop below 2200 when the engine is running and is about 1000 rpm too high in other situations. I think there a lot of the tachs in this vintage truck just shot.
Old Jan 17, 2013 | 02:28 PM
Conanski's Avatar
Conanski
The tach in my '90 did the same thing, it's an easy fix just remove the bezel and glass from the front of the cluster, unplug the tach module and plug in another from a donor cluster of the same vintage.
Old Jan 29, 2013 | 12:01 AM
Tectron1's Avatar
Tectron1
I just had a similar issue with my tach, it ended up being cold solder joints. I actually just posted a video if you want to see if it may help you out. never mind that I sound like a dork.
Old Mar 6, 2013 | 08:45 PM
Tectron1's Avatar
Tectron1
You tube keeps messing with me so I had to change the link again.
Rusty_S
Sep 8, 2015 01:08 PM
79boston150
May 6, 2009 06:43 PM
NNBlackGT
Nov 26, 2007 09:58 PM
sailorjohn
Bronco II
Aug 1, 2007 10:19 AM
SUPJDO
1983 - 2012 Ranger & B-Series
Aug 7, 2004 08:25 AM
