Bronco II Ford Bronco II
Tach not working
Old Jul 29, 2007 | 10:15 AM
sailorjohn's Avatar
sailorjohn
Tach not working
Well I've finnaly got my truck running well. Now on to fix other things like my tachometer. It’s not working and I don’t know why. How do I diagnose where the problem is?
Old Jul 30, 2007 | 09:35 AM
kernel-panic's Avatar
kernel-panic
You'll have to trace the wiring from the ignition coil and maybe the TFI module. I know on most standard ignitions, the tach is ususally connected to the coil negative terminal (I believe it's the green and whatever color striped wire). If you have continuity from there to the instrument cluster and you have a known good aftermarket tach (or better yet, a tach/dwell meter) to temporarily connect via alligator clips and the aftermarket tach (tach/dwell meter) works properly, you'll have to go and find one in a junkyard to pull.
Old Aug 1, 2007 | 10:19 AM
sailorjohn's Avatar
sailorjohn
Okay thanks for the help. The tach/dwell meter works. I am assuming my dash tach is bad so I'll be looking for a used one at the junk yard.
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
vortec 1
Nov 28, 2018 10:44 AM
BII Plow Truck
Feb 17, 2017 01:52 PM
unlucky2.1_7.3PSD
Jul 19, 2016 02:14 PM
rockher_man
Jul 15, 2009 11:30 AM
