Sponsored by: Real Truck
Exhaust
Old Jan 16, 2013 | 09:44 AM
Witchdoctor's Avatar
Witchdoctor
Exhaust
I have a 2000 F250 Crew cab Diesel 4x4. I have been told that I should change my exhaust to straight back, no muffler, dual independent pipes. Will get any benefit from removing the muffler and making the exhaust dual and independent from each other?
Old Jan 16, 2013 | 10:41 AM
bbender85's Avatar
bbender85
true duals on a diesel, eh?
Old Jan 16, 2013 | 10:44 AM
Kdr358's Avatar
Kdr358
There is no way to make it truly independent due to the downpipe. You would have to use a Y pipe. What are you trying to achieve? I personally am going with a 4" no muffler for my excursion.
Old Jan 16, 2013 | 10:49 AM
Witchdoctor
I am not trying to accomplish anything. I friend has a truck like mine and he eliminated his muffler and said he gets more power and better economy. He then said that he was advised to split the exhaust. So I am simply seeking advice.
Thank you for responding
Old Jan 16, 2013 | 10:58 AM
Kdr358's Avatar
Kdr358
From what I've gathered you don't gain much power. However removing the muffler and going with a 4" and a HFO you'll see a decrease in EGT's and a slight bump in power. Adding a Y pipe will probably create the same EGT's as a stock system.
Old Jan 16, 2013 | 11:01 AM
Witchdoctor
Ok, Thank You
Old Jan 16, 2013 | 01:10 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Splitting the exhaust does NOTHING for performance or economy because you still have a single outlet from the engine.. Your turbo. As far as the muffler, you can add it or remove it. You will never feel the difference in the pedal or economy.
Old Jan 16, 2013 | 02:39 PM
wizkid00104's Avatar
wizkid00104
Twin turbos would let you do that
Old Jan 16, 2013 | 03:27 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I like the way you think...
Old Jan 16, 2013 | 03:31 PM
wizkid00104
Probably not the most cost effective route, but who cares
Old Jan 16, 2013 | 03:32 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Like others have already said, the only way to get true dual exhaust is to add another turbo.
Removing the muffler makes your truck louder.....that is all it does. There are no other benefits. My wife's truck had it's muffler removed by the previous owner. It's the loudest and most lethargic truck in our group. Also gets the worst fuel economy.
Old Jan 16, 2013 | 03:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Here is my truck's exhaust. MBRP 4" turbo back with muffler. You cant be mad at this sounds can you?!
And for fun.... while filming the 'while driving' video
Lawdog734
6.7L Power Stroke Diesel
Aug 30, 2018 03:34 PM
jhobbs26
Feb 11, 2016 08:08 AM
06F150Guy
2004 - 2008 F150
Dec 7, 2010 09:47 PM
Wr3ckin_Cr3w
2004 - 2008 F150
19
Apr 11, 2007 01:59 AM
harem Scarem
Nov 11, 2004 02:11 PM
