muffler restictions
Old Nov 10, 2004 | 01:04 PM
harem Scarem's Avatar
harem Scarem
Question muffler restictions
Hello
What would indicate a restricted muffler or exhaust?
Old Nov 11, 2004 | 08:37 AM
shotgun1987's Avatar
shotgun1987
if the catalaic converter is pluged it will get like cherry red and start glowing in the dark
Old Nov 11, 2004 | 01:42 PM
harem Scarem
response to shotgun1987
My truck doesn't have a catalytic convertor. But would the muffler do the samething?
Thanks for post.
Old Nov 11, 2004 | 02:11 PM
big hoss 29's Avatar
big hoss 29
With a plugged exhaust, you will have a big drop in power with no apparent cause. Start the truck and go back to the exhaust with the thing running and listen to the exhaut pipe. If it sounds good with exhaust coming out like it should, it's ok. If by chance no exhaust is coming out, it's plugged and you could damage the engine if you run it with a plugged exhaust.
If you think the exhaust is plugged, you could take a hacksaw to the pipe before the muffler, cut off the muffler and run the truck to see if it helps.
You can get glasspack mufflers to replace the clogged one or just get a new exhaust system.
02Ford150
1997 - 2003 F150
Jul 24, 2013 02:16 AM
pamelbert
6.4L Power Stroke Diesel
Feb 27, 2008 07:13 PM
rebocardo
Exhaust Systems
Jan 13, 2003 11:50 AM
bobbyboy
Jul 30, 2002 04:34 PM
